Looking for tires
Old Dec 2, 2017 | 05:40 PM
Kim Hil's Avatar
Kim Hil
Cruising
Default Looking for tires
Recently purchased a solid 95 C4. Tires on back not so good. All away around is Firestone Firehawk.
Back tires are P285/40R17 Firehawk.
Apparently they are not available any longer in this size.
Is there someone out there I can buy a pair of Firehawk P285/40R17 from (used or New)?
Otherwise I'm being told Continental is the next best thing?????
Old Dec 2, 2017 | 06:22 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Ask that question in the C4 section for a better response
Old Dec 2, 2017 | 07:25 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
Agree with dahogan you'll probably do better in the C4 section. Here's the link to C4 buy/sell: https://www.corvetteforum.com/forums...ale-wanted-55/
Good luck with your search.
Old Dec 2, 2017 | 08:38 PM
jehuds10's Avatar
jehuds10
Welcome to the forum!
Old Dec 2, 2017 | 09:43 PM
Moving this to C4 General.
Old Dec 2, 2017 | 09:55 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
I'm wondering if the stock size was 275 40 17 (rather than 285)
Lots of choices in 275/40R17 ... If you want to stay with the Firehawk, tirerack.com has them.
Old Dec 3, 2017 | 07:40 AM
Kim Hil's Avatar
Kim Hil
Cruising
Thanks for the input. I will post my question in the C4 section.
Old Dec 3, 2017 | 02:25 PM
c4cruiser's Avatar
c4cruiser
285/40-17 was the OEM rear tire size for '93 and later C4's with the base suspension. But the rear wheels were 17x9.5" and those wheels will easily handle a 275/40 tire. There would be a small difference in the tire diameter and tread width. You may want to consider finding another pair of OEM wheels in 17x9.5" and using 275/40-17 tires on all 4 corners. That way you can rotate the tires for longer tread life. Also look at the NITTO G555 G2 tires. They are a very good summer high performance tire and the tread pattern works well in the wet.
Old Dec 3, 2017 | 06:45 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Try America's Tires.
Old Dec 4, 2017 | 10:37 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
I have a set of NITTO G555 G2 that I just got this summer. I am really unsatisfied with them. They flat spot within a week sitting in the garage. Over the last 40 years of having high performance cars, I have never had tires that flat spotted in a week.
I talked to a Nitto rep, he said put your car on jackstands. For a week ??
Your mileage may vary ie: YMMV, but I wouldn't recommend them. I am going to talk to the folks I bought them from.
Old Dec 4, 2017 | 11:48 AM
Barrier's Avatar
Barrier
Default Tires
I went thru this on my '93 4 months ago.
I was going to go with the 9.5 rims and bought a set. After researching this I decided to stay with the stock 9.5, and 8.5. The only advantage I could find was the ability to rotate front to back. My old tires were the Nitto 555s and after 6 years they were Dry Rotted. If the new ones Nitto NT555 G2s last 5 years with very little wear why bother to even think about Rotation.
GM chose the different size front and rear to limit tracking in ruts on the road.
I thought finding Tires would be a problem find Tires, Not an issue.
I believe my cost was about $600 from Discount Tire. Had the installed at Costco.
After 1500 miles I am very pleased, no flat spotting at all. Ride and Handle great. My car is used mostly on weekends.
I will be selling the 2 9.5 rims I bought.
Barrier
Old Dec 4, 2017 | 01:19 PM
drcook's Avatar
drcook
My Nittos were built in the 25th week of 2016. I will be taking them up to the retailer I bought them from (spoke to them today) so they can see the flat spotting. You can measure it with a dial indicator and the flat spots stay until the tires are warmed up of course.
The weather here in Ohio is not as warm all year as some of you enjoy, and they seem to be worse when the temps are below 50. So in a day or so when it is cold, the 2 front are going or I will drag the manager back to the house to take a ride on cold tires. I could understand if I was letting it sit all winter, but a week ?
I will let all of you know so you can be aware. They shake my car like I have square wheels and it is unacceptable to have to go drive around to warm them up before getting on the expressway.
Old Dec 4, 2017 | 09:10 PM
jdlclam's Avatar
jdlclam
I put a set of Nitto NT555 on my ‘94 last December, drove the car a few times on dry Michigan winter roads, and have about 3k miles on them. Even took it put for an hour last night with temps in the upper 30s.
Car probably sat in the garage for two months (mid-Feb through early April) due to weather. No problems with flat spots, they ride good and quiet - I’m very pleased with them.
Old Dec 5, 2017 | 01:00 PM
2LZ's Avatar
2LZ
It depends on your driving habits. I drive year round. post-100' in the summer and lots of rain and cold in the winter. I got these and really like them. Very forgiving ride but again, I don't race the car or run a track. Just a driver.
https://www.tirerack.com/tires/tires...Speed+Rated%29
Old Dec 5, 2017 | 03:17 PM
DGXR's Avatar
DGXR
I bought a set of Continental Extreme Contact DW about a year ago for my 1995 coupe. They will also flat spot in a week but it smooths out very quickly -- only takes about 5 minutes of highway driving even in our "cold" 35F winter temperatures. I wonder if you are overly sensitive to the vibrations? How long does it take to smooth out the flat spots in your cold temperatures?
To Looking for tires
