Help D44 OR D36 ?
Old Dec 6, 2017 | 01:02 PM
GaryInArizona's Avatar
GaryInArizona
Default Help D44 OR D36 ?
Hi all, I need to know how to tell if I'm looking at a D44 OR A D36 a guy has one for sale not to far from me can some one tell me what to look for ? Thanks
Old Dec 6, 2017 | 01:33 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
EDIT: Pic inserted was wrong
Old Dec 6, 2017 | 03:39 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Tom, not being a d*ck, but that picture is wrong. Look here:
https://www.corvetteforum.com/forums...dana-36-a.html
my 1996 FSM agrees the the snapshot of the FSM in the link above
https://www.corvetteforum.com/forums...-you-have.html
Old Dec 6, 2017 | 05:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You're right! That pic is bassackward.
Here is a better one.
Old Dec 6, 2017 | 06:11 PM
GaryInArizona
Thanks every one GOT IT its a d 36 with 3:73 gears complete with batwing with coil over shocks ready to bolt in what do you think a fair price is?
Old Dec 6, 2017 | 06:45 PM
pologreen1's Avatar
pologreen1
How much power do you have?
Do you plan to get traction?
What intake or year car?
What trans do you have?
Do you want coil overs? they are nice if you know how to adjust, but can be worse if not having a real understanding of them.
Old Dec 6, 2017 | 09:37 PM
GaryInArizona
Hi I have a stock 91 TPI 6spd just looking for lower gears the coil overs come with rear end don't know if I will use them ? Just don't know what its worth?
Old Dec 7, 2017 | 12:12 AM
383vett's Avatar
383vett
You would be giving up a stronger Dana 44 for a weaker 36. I wouldn't do it behind a manual tranny.
Old Dec 7, 2017 | 12:30 AM
WVZR-1's Avatar
WVZR-1
OP - and your drive-shaft is going to be to short as well as the C-beam.
If you've a '91 M6 it's either a 3.45 or maybe a 3.54 (there has been '91 3.54 builds) appear.
I'd say you leave it where it's at.
If it's complete is it an '88+ with just calipers or is it '87 and earlier with a drum e-brake. If there's information on the shock tubes you could maybe ID them. Much depends on what's actually here.
You need to understand all of this stuff to establish value. Just because there's coils on the shocks it doesn't make it a "premium" package.
Old Dec 7, 2017 | 08:06 AM
ghoastrider1's Avatar
ghoastrider1
I bought a D 44 to replace my 36. I also brought home the drive shaft and the support beam which I was told were a different length than what goes with the 36. I paid 800 bucks for one with less than 36K miles on it. Might be cheaper for you just to buy the pumpkin gears to swap out. best of luck
Old Dec 7, 2017 | 12:46 PM
GaryInArizona
Thanks for info every one going to stay with the D44.
To Help D44 OR D36 ?
