Really pulling hard right...
Old Oct 11, 2002 | 05:28 PM
GRNVNM93's Avatar
GRNVNM93
Default Really pulling hard right...
then i get home and look at my tire and it's nearly flat! I was accustomed to SOME pull to the right, but this was crazy!! So after plugging the tire (yeah i know, no more 150mph jaunts) i was wondering what PSI everyone runs in their tires for longevity of the tire. I put about 32 PSI (cold) in mine. That about right?
Old Oct 11, 2002 | 05:31 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Really pulling hard right... (GRNVNM93)
I usually run 42 psi in the 315s in the back...and 38 psi in the 285s on the front. (both cold pressures) That's what gives me even treadwear.
Old Oct 11, 2002 | 05:44 PM
GRNVNM93's Avatar
GRNVNM93
Default Re: Really pulling hard right... (Alchemist)
I have the stock configuration 255's up front 285's in back, if that matters...
Old Oct 11, 2002 | 05:47 PM
Alchemist's Avatar
Alchemist
I've heard of folks running as high as 45 psi on 255s...but ya wanna run what gives you your best treadwear....that is...til ya hit a track! :reddevil
Old Oct 11, 2002 | 07:54 PM
WEF's 95's Avatar
WEF's 95
on my 95, whatever the door sticker said (30 I think) caused the fronts to round off the edges. No problems after running 32 cold all around.
Old Oct 11, 2002 | 08:35 PM
minnasotajim's Avatar
minnasotajim
32 lbs up front
31 lbs in back
Old Oct 11, 2002 | 10:25 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: Really pulling hard right... (minnasotajim)
I have the same configuration as you...I run 30 all around except at the strip when I drop the rears to 24...BTW I have Eagle GSC's...
To Really pulling hard right...
