Water pump and optispark OUCH!!!!!
1996 conv 6spd with 90k. WP and Opti went yesterday, Since daily driver, needed mechanic to fix. not cheap, but fast and done right. Pick up today, Wish I had a couple of days to do myself
It is a hard choice having some one else do the install but it is a job i wish i sent out because the warranty now is in your installers hand and you do not have to chase the parts supplier if there is a problem.
Took me two months of mostly pounding on that balancer. Some here say it's a two hour job.
Also, because so many GM apologists among us here claim that the Optispark is being replaced in error, how did you determine that yours failed? I pulled mine because of the WP gusher, even though it was still working. Turned out the rotor had spit out a screw inside the cap and the bearing had excessive play. It might have gone another 10K miles.
Book time is 4 hours. I'm sure the new pump was 200, the opti was 300, so I'm gonna guess they charged right around a grand to fix it.
Really not too bad, better than paying a grand for a single electronic component.
Did you have them do all the "while you're in there" stuff too? Like plugs, wires, timing seals, hoses, knock sensors, coolant, etc. Would you mind sharing the extent of the OUCH? I'm curious how much I saved busting my *** replacing all that stuff.
Oh yeah, $1,200 out the door. Kept old opti to trying to rebuild when this one goes. Should have gotten drain hoses for weep holes, but another day. So much for headers/cats and 1.6 rockers. Summer will be a good time budget wise. I am finding out that a'vette and racing sailboat tends to drain the wallet
I took a day off work when I did my 1995 opti cap at 100,000 miles. Replaced water pump, hoses, plugs, wires, opti cap and rotor, balancer, timing chain/gears and seals incluging water pump drive shaft seal.
Finished it the second day. Pulling and installing the balancer was easy because I used the proper tools. It was just too much money to pay for. Didn't rush as I had never done one before. When the NAPA water pump failed the next year I knocked it out quick.
Had all this room to work with!!!
Hoses were good (just replaced), coolant sensor done, all other sensors tested good, plugs and wires replaced. Having had a '67 MGB, water pump/optispark replacement would not have been difficult, except for time downtime.
If you have a 1996 six speed manual, it is an LT4 and you already have the 1.6 (roller) rockers straight from the factory, courtesy of GM! Used to race Highlanders and Lightenings, not sure I could afford that and a Corvette at the same time but, at least you don't have to buy rockers.
So if I back out the cost of parts, doing the work myself saved about $700. Not a bad job at that rate.
My WP was missing about 6 bearings; Opti looks OK. Hopefully, there won't be a next time. If so, I'm doing it myself. What could possibly go wrong???????????????????????
It's not too bad, had my laptop out with me under an awning when I replaced the opti and pump, and pulled the truck around to use the tailgate as a workbench. Took about a week with having to stop for work and having to keep looking back at the manual on the laptop and looking at some videos to see what it was talking about. Think the worst part was putting the balancer back on, I couldn't get the tool in there correctly, so I torqued the hell out of the balancer bolts to get it back on. Probably not the best idea (actually come to think of it, it was a really stupid idea), but it's on now, probably forever. I just hope it lasts long enough to either trade her up or swap in a different engine.
Did you replace the Opti, then? I was going to say that with the 95/96 vented Optis, a coolant spill probably isn't going to hurt it. And if you did replace it with a new non-OEM one, then don't throw it away! The module in that thing, at the very least, is worth keeping, If the bearing is still good, the whole thing is worth keeping.
It' really not a bad diy job, and it will probably last you 15 or 20 years. I don' get people complaining about it. These cars are all over 20 years old by now, stuff will need replaced. Every 20 year old car will.
An LS1 harmonic balancer would cost you more than your opti did, and one of those failing can destroy the engine.
