High idle
Old Mar 16, 2018 | 04:41 PM
pa28 180's Avatar
pa28 180
5th Gear
Default High idle
1993 5.7 has high idle about 1200 to1000 rpm continues after car is warm does drop about 200rpm when shifted drive
Old Mar 16, 2018 | 06:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
is the check engine light on?
Old Mar 16, 2018 | 08:09 PM
aklim's Avatar
aklim
It says it idles to 1200 when cold and 200 when warm? I don't think so. I don't believe the engine can sustain itself at 200. If that is what you are reading, maybe something is wrong with the tach and you should check what the ECM thinks.
Old Mar 16, 2018 | 08:27 PM
pa28 180's Avatar
pa28 180
5th Gear
Default High idle
To clarify problem engine idles 1200 to 1000 rpm even when warm drops to 900rpm when shifted to drive no check engine is on ...any suggestions
Old Mar 16, 2018 | 08:50 PM
Nowhere Man
find a shop that is willing to plug it into a scan tool and read the pentameters of each sensor and see what one is out of wack
Old Mar 16, 2018 | 09:16 PM
aklim's Avatar
aklim
How do you know these numbers are right? Get a scanner. Gauge could be wrong
Old Mar 17, 2018 | 06:39 AM
mazdaverx7's Avatar
mazdaverx7
Have you noticed a drop in fuel mileage? Have you checked the engine over for any vacuum leaks? Have you cleaned the throttle body thoroughly? Those would be the first steps I would take.
Old Mar 17, 2018 | 10:24 PM
pa28 180's Avatar
pa28 180
5th Gear
Default Hgh idle
I tried cleaning throttle body ...no luck I'm concerned because engine seems to be running a little hot 215 to 225'f next step take it to shop to see if they can isolate problem thanks for all your suggestions!
Old Mar 18, 2018 | 01:02 AM
aklim's Avatar
aklim
Did you take it apart to clean it or just spray and pray?
What is the ambien temperature? What are you doing when you get it that high? Sitting in idle or what?
Often they have a "specialist" for that sort of job. IOW, some guy who drew the short straw and has to deal with old stuff nobody wants to work with. Sooner or later, you need a scanner to see things. Might as well buy one.
Old Mar 18, 2018 | 08:06 PM
FAUEE's Avatar
FAUEE
Sounds like you've got a vacuum leak. There's only a few vacuum lines, check to make sure they'e all plugged in. That's normal operating temperatures for an lt1, they run hot for efficiency and emissions.
Old Mar 18, 2018 | 09:06 PM
pa28 180's Avatar
pa28 180
5th Gear
Default High idle
did not take apart throttle body ...just spray and pray! outside temp. About 70 f each time car ran hot I've just been driving in normal city stop and go traffic
Old Mar 18, 2018 | 09:48 PM
aklim's Avatar
aklim
Probably right seeing it is an older car. As to the heat issue, assuming that the gauge is right I'd flush coolant and check for the trash in the radiator either way It's either full of trash or not. Can't hurt to check
Old Mar 19, 2018 | 12:05 AM
pa28 180's Avatar
pa28 180
5th Gear
Default High idle
Thanks will take a good look at vacuum lines
To High idle
