Considering a C4 - what to know
But, I don't know much beyond the basics. I would like a stock LT1, auto coupe. I know the optic-spark system can give headaches. Are there any common problem areas that should be checked out, beyond the basic used car inspection? Looking for something stock with no plans to mod.
I appreciate the input.
Get yourself a 95 or 96. Mileage is not that critical if there are good maintenance records. My car has 134K and still runs strong.
Most LT1 cars came with either 8.5" wheels in front with 9.5" in the rear or if you got the Z07 suspension (similar to your Z51) you got 9.5" on all 4 corners. These became the last vettes that you can run the same size wheels and tires and be able to rotate front to back. I run 275x40x17 some guys who autocross will go even wider but it's not really needed on the street. The car will already drive like a slot car.
Only the ZR1 and the Grand sport came with 11" wide rear wheels and you said your're looking for an LT1 car.
The 94 - 96 sport seats are expensive to recover because that group only comes with the foam already glued to the leather. (but they are IMHO the most comfortable ) If you're going with an A4 they came with two different rearend ratios 2.59 & 3.07 you want the 3.07.
Common problems: weather stripping, opti(great system, dicey replacement parts), tire condition/age, oil leaks(mostly due to intake on LT1/4 cars) and general wear, like any car.
When it comes to "stock" wheels on the year range you're talking about, '91-'96, they will all have the 17 inch sawblades, unless the previous owner swapped them. A subtle difference you may notice is that 91-92 have a flat "cast" look and 93-96 are machined and clear coated (a bit shinier).
Other than that, just little changes from year to year. All will have driver side air bags. Passenger side air bags replaced the glove compartment in '94. Interior lettering switched from orange to white in '94 as well as a different steering wheel and seat styles. If that stuff matters to you, just do some image searches or go look at a few different cars.
Tony: Look for "G44" and "G92" RPO codes under the center console (if they're still there on the car you look at).
All I can say is... its worth it.
Same as FX3, right ?
If you were not looking for an automatic a 1996 LT4 is the way to go. A lot of internal improvements in the engine that make them even more durable than the LT1.
Anyway, if I got a C4 I would cruise with it and put on some serious road trip miles. An LT4 would be nice and I appreciate that it is more robust, but getting an automatic would be an easier sell to you-know-who. And, when I want to shift gears I have the C6.
I have to start working on a neighbor 3 houses down. He has an LT1 C4 Auto that he rarely drives and has been complaining because his DD sits outside. A plan is taking shape...
When I bought my 92 it was bypassed and the seller denied knowing anything about it. But it ended up dropping the price by a grand.
I by passed a few because the power seats did not work...I couldn't even get behind the wheel to drive 2 of them!!
Good luck !!
My non-stock Z51 C4 is far more raw than stock, so 'she' is far more likely to go anywhere in my C5 than the C4. The C4 is a bit less travel friendly w/o a real trunk and a more snug cockpit.
If you just want a good running car that is reliable and won't require too much upkeep, I would not bother with any car that has modifications. A few small mods here and there to resolve known issues are fine. But any big changes to the body, suspension, drivetrain/performance, electronics, etc. I would walk away. Lots of these cars were made and you will find a good one in your price range, just don't succumb to Corvette fever during the search/shopping process -- an impulsive buy can be a big mistake. Take your time and find the right one for you... you might have to look a few hundred miles away like I did, but I found my car
