Low fuel pressure
Before anyone asks, the pressure is not beading off. It will hold the pressure for a while. It does start a little easier after it is warmed up. I am absolutely at a loss.
Also, If I crimp the return line at the tank the fuel pressure will shoot up to 100psi even at idle.
So here is what I would do next.
Install the fuel pressure gauge and start the car, let it idle. Then pinch off the return line somewhere you wont hurt anything, and watch the fuel pressure. If it comes up to something normal, or more likely way above normal, then you know the pump is capable of producing the proper pressure. As long as that's the case, then I would think the pressure regulator is malfunctioning. Which is a pretty darn rare occurrence (they frequently leak but that's different) but there's not really much else that could cause the symptoms you are describing. It is not impossible you have insufficient voltage/amperage to the pump.
32 psi is the normal fuel pressure for an 85 corvette, the 85 has 24lb injectors so they run the fuel pressure around 32psi. 23 psi is too low, should not drop below 30 psi.
Check the fuel pressure relay, make sure the pump has a steady 12 volts. Check the fuel pump wiring connector and ground wire are good.
Check the 3 way connector is making a good connection.
Check the vacuum hose for any fuel smell, if the fuel pressure regulator diaphragm is torn you can loose fuel pressure and have it sucked into the engine. Check the oil for gas.
The later C4 runs around 40 psi with slightly smaller injectors.
Good luck, should be something simple
I guess the only other thing I would want to be certain about is that your pressure gauge is functioning properly, and if it is, then I would probably just throw a new regulator on it and keep my fingers crossed.
Whatever happens, report back to us here once you get it figured out. Its an unusual problem for sure.
Lets try this. Crimp the return line and turn the key on but not crank. It should shoot up the pressure. See if it holds the pressure and for how long. Might be that the regulator is fine BUT IF the injectors are leaking that will lower pressure. Just to be through. Maybe something in the injectors is not closing all the way?
Lets try this. Crimp the return line and turn the key on but not crank. It should shoot up the pressure. See if it holds the pressure and for how long. Might be that the regulator is fine BUT IF the injectors are leaking and that will lower pressure.
FWIW, in case someone else is wondering, below is a fuel pressure chart from Charles Probst's book on Corvette fuel injection.
For what it's worth, he says 34 psi is at the bottom of the scale for a 1985 Corvette...
Anywayz, I wouldn't rule out the fuel delivery just yet: static pressure is one thing, but delivery AND pressure is another.
Ordinarily, I'd be saying to check the filter. But, you've already done that. HOWEVER, that doesn't mean there isn't some blockage elsewhere, e.g., a kinked/pinched fuel line, OR the fuel lines full of crud. The pump too is part of delivery, but save that for last.
AND, kind of an after-thought, and I don't mean to veer off topic, a plugged catalytic converter will result in drivability symptoms very similar to fuel starvation. (Just sayin)
This chart is for your (and others) reference and reading pleasure...
That said, It seems like you can hold pressure when the return line is crimped off. I have less doubt that it is the pump being unable to deliver. If it can push it up to 100 psi, I think it will deliver. Also, another test, like I said, would be to pressurize the system and see what it does at key on engine off. See if it holds. Someone also suggested a WOT run to see if the pump delivers. With your test being able to do 100 psi, I suspect the pump will deliver and the circuit holds pressure even at the pulsator. Doesn't hurt.
Now the car starts with just a bump of the start, NO MORE CRANKING for 20 seconds!! It doesn't try to stall when taking off, and it seems to have gotten it's performance back. I have not gotten to drive it much, since I had a flat and the tire is ruined. I had a bald 225/60 laying in the back, so I stretched that onto the wheel so I could get it off the side of the road (spare tire is missing). Going ahead and replacing all the cracking old tires.
While at the upper plenum and runners of I tried to clean the carbon and gunk from the inside. The best thing I found was LOTS of carb cleaner and a toothbrush, but it was not perfect. Does anyone have an idea for a better solution?
I decided to pop the fuel rail loose and look for injector leak. After about 10 min or so all of the injectors leak maybe a drop of fuel. At some point in time I will get a set of rebuilt injectors, but it is not that urgent, and I couldn't leave it apart where it was.
It looks like the regulator has plenty of adjustment left, so I may have had something in the line, but I don't know for sure.
The true test would have been to see what the volume and spray pattern is. It might hold pressure but if the volume is low or the pattern is poor, the fuel mixture might not be right.
That isn't the best way. The best way would be to hot tank it. Faster and cleaner if not as clean as with the toothbrush and way less hand fatigue. TB is harder to hot tank. For that one, I would take the top off, take the IAC solenoid off, take the IAC housing off. Clean the IAC pintle with a GENTLE spray of brake cleaner and hose down the passages and the rest of the TB gets the toothbrush. Obviously new gaskets are needed.
also aklim, I do have Bosch injectors, they are not multec.
The injectors are probably dirty and it is as cheap to throw them and replace with reman as cleaning unless you need original
