C4
Old Mar 31, 2018 | 04:23 PM
brbbowhunter's Avatar
brbbowhunter
2nd Gear
Default C4
Has anyone ever in counted there c4 running for around 10 minutes then it just shuts down. Wait a bit and it will start and do the same thing again. I've been told it could be the coil.
Old Mar 31, 2018 | 04:36 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
Wrong forum....you are a few generations ahead of your C4
Old Apr 1, 2018 | 12:56 PM
Kmcoldcars's Avatar
Kmcoldcars
You should always include the year of the car. C4s were made for 13 years, had at least 5 different engines, several different transmissions, different electronics, etc. The pertinent information related to the problem should also be included.
My 1991 had a similar problem. I finally discovered the computer thought the water temp jumped from about 160 F to 260 F in less than one second, and the car would then shut down. I eventually tracked it down to the likely culprit, and replaced the computer. That was it.
To C4
