94 LT1 - engine cuts out when using AC
Old Apr 1, 2018 | 02:36 AM
racerog1's Avatar
racerog1
Default 94 LT1 - engine cuts out when using AC
Car runs great when temp is less than 210 but when it gets hotter the idle surges up and down 1500-800 rpm. If AC is on and engine is hot (+210) engine cuts out / stumbles. When AC is then turned off - and temp drops below 210 the car runs normal - no cutting out. So, is there some connection between the AC and ignition timing?
Old Apr 1, 2018 | 06:25 AM
Paul Workman's Avatar
Paul Workman
A scanner would be my first choice: seeing whats-what first and go from there.
My wife's car (91 ZR-1) would often stall when rolling to a stop with the AC on. In that case, the Throttle Position Sensor (TPS) was in need of adjustment/re-cal. Once that was done, it ran w/o further stalling (for what it's worth!).
You'd want to scan it as a first step to be sure everything is in spec. Then also take a look at fuel pressure; see what it is doing.
Including the year would also help a lot.
Old Apr 1, 2018 | 03:37 PM
racerog1's Avatar
racerog1
Default 94 lt1 -
Ok thanks for the advice - I’ll try a scan to see what that reveals -
I already replaced TPS and MAF switches also new fuel filter - but none of those made any difference
To 94 LT1 - engine cuts out when using AC
