Broken key in door..help
Old Apr 5, 2018 | 08:13 AM
stabac's Avatar
stabac
Default Broken key in door..help
Broke door key flush with lock, any of you fprmer burgalers have a trick for getting it out????
Old Apr 5, 2018 | 09:13 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
picture?
Old Apr 5, 2018 | 09:18 AM
PatternDayTrader's Avatar
PatternDayTrader
There is a tool made exactly for this. It's just called a key extractor and it's part of most lock pick sets. Your local locksmith should have one. You could probably buy one off ebay.
Old Apr 5, 2018 | 09:31 AM
ZEN357's Avatar
ZEN357
Amazon Amazon
Old Apr 5, 2018 | 04:46 PM
Kevova's Avatar
Kevova
If you are unable to use pick tool to remove broken key. Lock cylinder can be removed and taken to dealer or locksmith. The bezel and and cylinder can be removed to increase access to broken blank. You can do the remove bezel and key door yourself, but you likely need to get replacement parts. Then have new key made and cover and bezel on cylinder replaced. There is a small gasket for lock cylinder to door they can fall off or crumble so you may need a replacement also. If you have a second key ;replacing the cylinder sometimes cost less the dealing with recovering the one and only.
To Broken key in door..help
