1988 Engine accessory bolt sizes?
Old Apr 16, 2018 | 03:33 PM
Richard Ames's Avatar
Richard Ames
Default 1988 Engine accessory bolt sizes?
1988 Corvette need to bolt sizes for the:
Water Pump
AC Compressor Bracket
Alternator Bracket
Air Pump Bracket
Power Steering Pump
Thank You (posted in C3 first in error )
Old Apr 16, 2018 | 06:04 PM
WVZR-1's Avatar
WVZR-1
Anything that bolts directly to an L98 cylinder head or engine block you should find being 3/8-16 and various lengths, there will also be a mix of bolts and studs.
Actual brackets and accessories can and will be a mix of Metric and USS. You have nothing or just a 'bucket of bolts'?
Old Apr 17, 2018 | 03:14 PM
Richard Ames
I have a few bolts. I was told that as long as you stay around 1/2 inch of the bolt in the block you are OK. Using a screw driver to check depth and old bolts to check size and pitch.
Is the engine and drive train SAE and the Body Suspension Metric?
Old Apr 17, 2018 | 03:37 PM
WVZR-1's Avatar
WVZR-1
An L98 water pump mounting bolt is spec'd @ 1 3/4 long so measure thickness of the flange and subtract from the 1 3/4, that should give you a general dimension of thread required for install. Confirming depth will keep you from 'bottoming'. I might use something other than a screwdriver to do depth and measurements, even the least expensive digital Verniers usually have a depth indicator.
It will change for the Metric hardware in the accessory bracketry. Generally speaking you want flange head hardware for the hardware.
NO to your generalities regarding SAE - Metric. The alternator hardware is M10x1.5 and M8x1.25. There's other mixes involved. To confirm threads I'd buy an M6x1.0, an M8x1.25 and an M10x1.5 to confirm all other than 3/8-16.
Compressor bracket to engine is 3/8-16 but the compressor to the bracket is M8x1.25 I believe. Force nothing - confirm and use thread chasers.
Old Apr 17, 2018 | 07:58 PM
Joe C's Avatar
Joe C
If the OP can get a copy of the "y-body parts and illustration catalog," hard copy or .pdf, most bolt/screw/nut part numbers, as well as sizes, are called out in detail. hopefully, this should get you started....
water pump - parts #88 and 95
Old Apr 25, 2022 | 10:16 AM
pkrbkr13's Avatar
pkrbkr13
I was looking at your reply about bolt sizes, and there is a bracket #9.171 that shows it mounts on studs. Do you know the length of the
upper and lower ones that nut #4 attaches to. This was on page 10-91 of GM service parts operations manual.
Old Apr 25, 2022 | 10:53 AM
WVZR-1's Avatar
WVZR-1
Year seems to matter along with bracketry. If the later 'denso brackets are used then hardware would change. I
3/8-16x2.73/3/8-16x1.32 and another that's spec'd @ 3/8-16 (both ends) 2.5 LG
Old Apr 25, 2022 | 11:55 AM
pkrbkr13's Avatar
pkrbkr13
Sorry to bother you. If i would've had the pump in my hand i would have seen the difference. Brain fog.
Old Apr 25, 2022 | 12:02 PM
topfuel67's Avatar
topfuel67
GM continued this with the LT1. I just did the intake manifold gaskets on my 92. The EGR valve (I think that's what it is) on the driver's side rear of the manifold is 3/8s heads. The similar valve on the passenger side rear of the manifold is a 10mm. Why is there a mix of standard and metric on the same part?
To 1988 Engine accessory bolt sizes?
