convertible deck lid protector
HI Friends,
I need to replace the protector on my deck lid. Are there separate protectors for convertible top and hardtop? Also, how do you remove the old one? Can I use a heat gun? Is there a foolproof way to attached the new one in the right location? Thank you kindly.
HI Friends,
The one I have will only go on one way as the tips must touch the door opening and the rear center must overlap and meet congruently.
The static cling ones are easy to move around, no issues. If you are using one with adhesive, I'd guess that a spray bottle of soapy water would help, like installing a big decal.
Greg Johnson (04-25-2018)
