Welding question
Old Apr 22, 2018 | 07:09 PM
mlm0's Avatar
mlm0
Default Welding question
I want to cut off the egr tube coming off of my exhaust manifold and then patch up the hole. It now has a block off plate on it, but it’s still in my way. This is the part of the manifold that connects to an egr electrical switch and then on to the back of the intake manifold
its cast iron and I don’t know if it can be patched even by professional welder
Old Apr 22, 2018 | 07:12 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
why do you want to remove it?
Old Apr 22, 2018 | 07:27 PM
pologreen1's Avatar
pologreen1
They can be, but headers are cheap and a big help on these cars.
I actually bought some old TPIS headers for $200 that need recoat (function over form for my car), but work for me. These had tubes, I asked they be cut off and welded, it was done in minutes.
Old Apr 22, 2018 | 07:29 PM
mlm0's Avatar
mlm0
I have removed egr and what’s left on the manifold sticks up right in my way every time I want to work on that side of engine. Right now I am trying to re route my spark plug wires, and the very nice stainless loom wire separator I bought can not be attached to the valve cover because that egr tube is in the way
Old Apr 22, 2018 | 07:31 PM
mlm0's Avatar
mlm0
whish I could find deal on headers. I believe headers are made of aluminum and my manifold is cast iron
Old Apr 22, 2018 | 07:37 PM
mlm0's Avatar
mlm0
If I don’t need egr, will a driver side manifold fit on passenger side also
1989 Vette
Old Apr 22, 2018 | 07:40 PM
pologreen1's Avatar
pologreen1
Headmans are like 150 new at summit non coated. Maybe 300+ coated?
Dump the old junk.
Old Apr 22, 2018 | 07:42 PM
mlm0's Avatar
mlm0
Dump the old junk.
from what I have read the cheap headman headers are a nightmare to install because of fit problems
Old Apr 22, 2018 | 07:44 PM
pologreen1's Avatar
pologreen1
I had them.
https://www.summitracing.com/parts/h...model/corvette
The price is cheap for the power they open, but it is your car.
Old Apr 22, 2018 | 07:57 PM
mlm0's Avatar
mlm0
How hard to install. Did you have to do mods
Old Apr 23, 2018 | 12:32 AM
mtwoolford's Avatar
mtwoolford
FWIW I've had excellent success brazing up old cast iron chevy exhaust manifolds; I'd suggest grinding off the egr tube, tapping the hole for an iron pipe plug, threading the plug into the manifold, brazing it, and then grinding the plug down even with the exhaust manifold. Cheap, easy, any Bubba with an oxy acetylene torch could do it for you.
To Welding question
