Stuck Knock sensor....
Flowing through the 'Vette Kart to do list, I got to where I wanted to drain coolant. No biggie, pull the KSS on one side and the oil cooler hose on the other side. Dudes.....that focking knock sensor was screwed in previously by King f'n KONG! I spun the hex in the housing, it was so tight. I figured that I was F'ed at that point, but i hit it with a trifecta of fire power:
*HEAT; I always say, heat it, use heat. Heat works...and it does
*Big pair of Vice grips; I clamped those suckers to the OD of the knock sensor at tightly as my two fists could clamp.
*The socket/ratchet on the hex.
I heated the bejeezus out of the block around the sensor, then chucked the torch and grabbed onto both wrenches...with my feet braced against a jack stand, I gave that son-of-a-bee, hell...and it moved. Re clamp...do it again. And again. And again. Probably 8 clamps/turns, before I could turn it by the hex alone. What a little MF'er.
If you don't have people problems, you don't have problems.
The KS on the passenger side in my Polo was corroded in place. Almost as much fun as that motherf***ing balancer.
Both would've been vastly easier on your lift instead of my jack stands.
