Cooling fan issue
Old Apr 27, 2018 | 06:51 PM
MikieG1971's Avatar
MikieG1971
Default Cooling fan issue
Today the car idled 30 minutes in 80 degree temp. Upon turning the car off, coolant overflowed from the resevoir.
What are common reasons why the fan would fail to come on?
1996 LT1 auto coup.
Old Apr 27, 2018 | 09:40 PM
belairbrian's Avatar
belairbrian
Did you try turning on the A/C to force the fans on?
Did you check the digital temp reading in the LCD?
Could be:
fuse
fan relay
fan
temp sensor
ecm
wiring
Old Apr 27, 2018 | 09:57 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
1996 LT1 auto coup.
I'm going to go ahead and say that the fans DID come on; I can't believe that you could go 30 minutes w/o massively overheating it, with no fans. Starting it "cold" -with coolant and oil at your 80˚ ambient temp, the engine should warm to 230˚F in less than 10 minutes.
I think your fans are coming on, but your cooling system needs all the same typical maintenance the many folks' do. Clean debris from in front of the radiator, and flush the system out.
Old Apr 28, 2018 | 01:08 AM
MikieG1971's Avatar
MikieG1971
Fan did come on with a/c turned on. The coolant system was flushed one month ago using a cleaner and the thermostat was also replaced.
Old Apr 28, 2018 | 09:37 AM
Paul Workman's Avatar
Paul Workman
Well, having recently dealt with coolant overflowing issues, some things in your initial post popped out at me:
Too "coincidental"?
IF the system was recently flushed and refilled and properly "burped", the level in the overflow reservoir shouldn't have been filled above the "COLD" line before the engine was allowed to come to operating temperature. Otherwise there won't be sufficient reserve space in the overflow reservoir for expansion, once the engine heats up!
OR...Air leaking into the system* will result in coolant not being drawn back into the system as the motor cools. (This is a major clue of air leaking into the system!) Next time the motor is started, the temp may zoom up quicker and higher than normal, and coolant overflows from the overflow reservoir, especially after the motor is shut off (trust me!).
*Radiator pressure cap or using a screw-type hose clamp in place of the factory spring clamps very often a source for trouble! (Dang screw clamps are easy to install, BUT they also require periodic checking to see they haven't lost their grip. Spring clamps are a bitch to deal with w/o the proper tool to remove/replace them, but damn well worth it in terms of trouble-free installation!!)
Old Apr 28, 2018 | 09:39 AM
belairbrian
OK since yours is a 96 the fans work a little different than my 92. Looking at the wiring diagram: when the system hits 219 both fans should come on at low speed. This is done by placing the fans in series using the contacts of a de-energized third relay. When High fan is commanded relays 2 and 3 energize placing the fans in parallel.
My suggestion would be verify radiator is clear of debris.
Refill cooling system.
Start car and monitor coolant temp on the LCD display. When it reaches 219 both fans should come on. If they do then you have another issue.
Could be as simple as a bad radiator cap or as bad as a bad water pump or clogged radiator.
Did you just buy this car? Has it previously worked properly? The reason I ask is if relay 3 is replaced with a 4 pin relay the low fan circuit could be disabled. At least that's the way I read the circuit.
Also a defective relay 3 could cause no low fan function.
Old Apr 28, 2018 | 12:51 PM
johno504's Avatar
johno504
St. Jude Donor '19
Default reprogram ecm
the 1996 OBD2 cars can be reprogramed thru the ECM to turn the fans on at lower temp. even though my car has a manual fan override switch I did the reprograming and consider it money well spent.
Old Apr 28, 2018 | 05:45 PM
MikieG1971's Avatar
MikieG1971
All very good suggestions. Is there a way to check these relays?
Also, what is the proper burp technique?
Old Apr 28, 2018 | 06:05 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
As noted in post #3 & #7 you need to check to insure that the radiator is clear of debris. The system may have been flushed but if the radiator fins are clogged with debris (which VERY often they are) the system will not function properly. This also holds true if there is a bunch of debris between the AC condenser and the radiator.
On the 95 (and I believe your 96 functions the same way):
First fan comes on around 227 degrees
2nd fan does NOT come on until around 237 degrees.
BUT when car is standing still and you turn on the AC.... BOTH fans come on at their high speed. (this is pretty easy to check).
Old Apr 28, 2018 | 07:20 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Have you checked the "in between" space for the radiator and the AC condenser? You can have a super squared away system and if the junk in between blocks your air flow, nothing will keep your car cool.
Here is what I found with my "perfectly normal" system that over heated. I cleaned out the junk and the system worked perfectly.
Old Apr 29, 2018 | 06:09 AM
kenmohr's Avatar
kenmohr
Yep me too
Old Apr 29, 2018 | 10:06 AM
MikieG1971's Avatar
MikieG1971
Did you have to take it apart to get it clean?
As i said in my battery thread. I am slowely going thru this car upgrading and modernizing as i go. I am looking at going to a 3 row polished aluminum radiator, new water pump, hoses, and high performance fans.
You might say, "thats alot of $ for nothing". I am planning the powerplant overhaul. My choices are, rebuild the current LT4 to 383, 500 rwhp. This is likely to go upwards of 10k, Or..... just suck it up and drop some coin on a new GM LT4 plug and play crate engine.
A super charged 650 hp engine will probably require rear axle mods. Sounds like a fun toy huh.
With my kids all grown up, and no wife, i can finally have a cool old hotrod Corvette!!
Old Apr 29, 2018 | 12:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Take the upper shroud off, then look/clean down between the rad and the AC condenser.
Old Apr 30, 2018 | 06:44 AM
kenmohr's Avatar
kenmohr
The first time I did mine I pulled the radiator
To Cooling fan issue
