Does ATF break down with age?
Everything online says this is basically a bulletproof transmission not to worry about. I read through the original owner's service records and found that they never had the fluid and filter changed ever. So while my car has only ~74k miles, the ATF is 26 years old. Should a fluid/filter change be in order? Also approximately how much should one pay for that service?
I also plan on pouring in a bottle of Lucas Stop Slip tomorrow. Ive never used it in a Corvette (or any other RWD auto) but I have put plenty of the stuff in beater Hondas/Toyotas with 200k+ and was really impressed with the results. If the Lucas works should I just forgo the fluid and filter change until 100k like the manual says?
1) It's not bulletproof. Not by a long shot.
2) There IS a chance of washing plaque loose and sticking the governor or other controls when doing a fluid change at an interval that long, but having said that.. I would do it anyway if it were mine. I can't imagine running 26 year old ATF and the moisture and nastiness that would have to be in it by now. But, be forewarned that there is a small chance it can cause problems.
3) I'm not a fan of fixes in a can. But, if you have to use one, Lucas seems to be one of the more benign ones. Appears to raise viscosity, but doesn't overtly attack the seals and attempt to swell them like other products I've seen. (And I've seen some very severe effects and damage arise from using these products.)
I dunno if it is even still down there, but somewhere in the storage room of the shop there is a tupperware container of Lucas mixed up with ATF, and there's a front seal floating in it. I stopped checking it for damage after a few years of constant immersion because I never noticed anything appreciable. So, there's that.
4) I would absolutely change the filter also.. Yes. Be sure you get the old seal out of the pump and make sure the new one fits well. The flexible pan gaskets are nice. Farpack works well too. If you end up with cork, drive it a few weeks and then snug the bolts to prevent leakage.
5) If you thought you felt a slip, take a look at the TV linkage real quick and make sure it hasn't backed off.. The adjuster is plastic and it's old plastic at this point.
Regards and good luck!
When specifically was the slip? 1-2, 2-3....?
There is lots of info online to diagnose it yourself. That doesn't necessarily mean you can fix it.
I am not a microbiologist and I never plated a fluid sample, so I dunno if the stuff was growing in the ATF, or in the condensation riding on it? Or in the housing? I'm not sure..
But I know I would absolutely, without question, change out 26 year old fluid without so much as a second thought, and regardless.
Because it's a contaminant and it's totally gross.
It really is simple
D.
