I use a 12volt battery charger , salt and vinegar , and round cotton pads , sticker (corvette logo) and adhesive plotter paper
I cleaned the plenum and put the sticker on , now i put the cotton pad in the mix of the salt and vinergar . Connect the positive wire from the charger on the plenum put the wet cotton pad on the plenum sticker , i take the negative wire and put it on the wet cotton pad for a 20 seconds and look if it‘s deep enough . I repeat this till it‘s fine to me . i cleaned the plenum again and put the foil on and cut out the flames and do the process over again . Now clean and pollish .
I‘m from the Netherlands . I’m working on improving my English .
Very nice work!
PS...your English is better than many of us “English first language” folks!
