Help Stranded
Old May 11, 2018 | 11:35 AM
Gatorlaw's Avatar
Gatorlaw
Default Help Stranded
I drove to work this morning and everything was fine. I went out at lunch to run for a quick trip and the car wouldn't start. It turns but won't start. I have recently replaced the fuel pump and filter (about a year ago). All I know is its friday and unless I can come up with an easy fix, looks like I'll be waiting on a tow as I have no tools here...
Old May 11, 2018 | 11:44 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I wonder what year car this is?
If I were you, I'd be checking for spark, and checking if the fuel pump is running @ "key on".
Old May 11, 2018 | 11:53 AM
Gatorlaw's Avatar
Gatorlaw
It's an 88 C4. I can hear the fuel pump when I turn the key. I wait until it cycles then try.
Old May 11, 2018 | 12:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Check for spark.
Old May 11, 2018 | 12:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Check your "inj" fuses. It's pretty unlikely that they'd both blow, but...it''s easy to check 'em.
Old May 12, 2018 | 08:32 AM
Gatorlaw's Avatar
Gatorlaw
So i came out after work and she fired right up and ran great. Now I’m really confused.
Old May 12, 2018 | 09:03 AM
84 4+3's Avatar
84 4+3
Factory injectors?
Old May 12, 2018 | 09:30 AM
pologreen1's Avatar
pologreen1
maybe look in to vats issues.
Old May 12, 2018 | 10:24 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Probably not VATS.
Old May 12, 2018 | 12:14 PM
mickey5's Avatar
mickey5
My '90 did exactly the same thing as the OP several years ago. Drove it about an hour with no problem; shut it off and little later it wouldn't start. Left it for several hours and it started right up. Turned out to be a heat soak problem and failing injectors
Old May 12, 2018 | 12:26 PM
confab's Avatar
confab
Ign module?
Old May 12, 2018 | 01:12 PM
Gatorlaw's Avatar
Gatorlaw
Started right up this morning. Ran to the store, come out fired right up again. Drove to another store ran in came out the car fired up then started missing. Tried to restart, nada. Gave it a minute, fired right up and ran strong all the way home.
this is perplexing to say the least. Don’t want to toss cash at an unknown but I’m sure this is a preview of coming attractions...
Old May 12, 2018 | 01:18 PM
mickey5's Avatar
mickey5
It will only get worse. Call Jon at FIC and get a new set of injectors ASAP.
Also if you get stranded let the engine cool for an hour or so and if it starts right up high tail it for home. Mine was good for 15 minutes or so before the missing started.
Old May 12, 2018 | 01:42 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It all depends on how you'd like to proceed; you can pick one of the WAG's presented thus far, and throw parts at it, or you can test and prove what the problem is and replace just that part. When the symptom occurs, what's missing; spark or fuel?
Old May 12, 2018 | 02:24 PM
confab's Avatar
confab
Play with it in the driveway a little and try to duplicate the condition with a gauge on it and a spark tester in your hand?
Because eventually, it will probably come back on a wrecker. I don't know what a tow costs there, but here it's crazy high. High enough to pay for a FP gauge and a spark tester.
Old May 12, 2018 | 05:15 PM
Gatorlaw's Avatar
Gatorlaw
So I go out and fire up the car, don’t hear anything odd. Figure i need some testing so i close the hood bump the door and the drivers door closes while the engine is still running. No problem, go inside to get the spare and they are not there They are with my daughter a hundred miles away. So i call AAA and request a locksmith. While I’m waiting I’m trying everything I can with the coat hanger. Watching the temp gauge debating whether I’ll have to break he window to save the engine. It took me an hour and change but i was able to get the window down just as the locksmith pulled up. Well at least the cooling system is good....
Old May 13, 2018 | 02:12 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
you would have to have more than one injector failed. I don't think that's very likely. Not for it to happen at the same time. More likely is the ignition control module or some kind of wiring issue with the injectors.
Old May 13, 2018 | 11:52 AM
esham's Avatar
esham
Default Ecm?
Could also be the ECM. My 90 did the same thing. Only happened once the car was warmed up.
Old May 13, 2018 | 02:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sounds like a tough day.
We still gotta confirm spark or fuel though.
To Help Stranded
