armrest saver?
Old May 14, 2018 | 06:12 PM
sb66's Avatar
sb66
Default armrest saver?
hey everyone
I ran across the armrest saver from zip, Wilcox and ecklers and wondered if anyone has tried them and had any thoughts?
https://www.ecklerscorvette.com/corv...989-31405.html
Wilcox
https://willcoxcorvette.com/corvette...st-saver-84-89
thoughts?
thanks
Old May 14, 2018 | 06:15 PM
confab's Avatar
confab
I have Wilcox installed in mine..
Seems to work well. It really does feel like a hard yank on the armrest would break it, otherwise.
Old May 14, 2018 | 06:17 PM
confab's Avatar
confab
PS: Thanks for taking the time for me when I PM'ed you about your wheels a year or so ago. Linking them and all that.
I ended up getting some just like them. PMD finish and all.
They look great!
Old May 14, 2018 | 06:24 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Of course if you had an OPTI-SPARK C4 you wouldn't need those braces.
OPTI-SPARK C4's came with much more robust arm rests
Old May 14, 2018 | 06:42 PM
sb66's Avatar
sb66
They look great!
that's great to hear - I am glad it helped!
Old May 15, 2018 | 09:06 AM
toddbvanslyke's Avatar
toddbvanslyke
Forgot where I bought them but they seem to strengthen the armrest pretty dramatically. Had to ream out the screw holes to properly fit but that took only moments with a rasp.
Old May 15, 2018 | 09:12 AM
confab's Avatar
confab
If you remove the armrest, you could actually see where the plastic under the screws in that pocket was breaking up, leaving you to basically pull on the foam. Maybe it's wear or over tightening? But the supports helped.
Old May 15, 2018 | 11:31 AM
sb66's Avatar
sb66
thanks - found some and they are on the way - you can clearly see where the pad is starting to separate - perhaps a little glue in there -after the new support- will help
Old May 15, 2018 | 12:48 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I had a set in my C4 for 20 plus years, you will notice immediately when you crap the door and pull to close, how strong your arm rest just became.
Simple installations, two screws if I remember!
That's one of the better mods to give your car!
Old May 15, 2018 | 01:37 PM
biggiefl's Avatar
biggiefl
Anyone have a pic of this?
Old May 15, 2018 | 04:24 PM
sb66's Avatar
sb66
I have a couple of links at the top for what the pieces look like but they are not installed
Old May 15, 2018 | 05:41 PM
biggiefl's Avatar
biggiefl
Gotcha
Old May 16, 2018 | 07:30 PM
1cooldaddyo's Avatar
1cooldaddyo
My door panels were completely destroyed when I bought it, just held together by good thoughts.
I made some of these out of an old license plate and now the armrest/door pull is the most solid part of the whole thing.
I'm sure store bought ones are even better.
To armrest saver?
