normal temp range?
Old May 17, 2018 | 08:44 PM
84Whitebird's Avatar
84Whitebird
Default normal temp range?
had my newly acquired 84 out today. first time in warm/hot weather. 81-83. running down the road it was at 180-185. sitting in town at lights and such ran up to 210-215. fans were coming on. Is that in the normal range? My 92 Firebird did the same. My 94 Firebird NEVER got that warm. I have run Red Line "water wetter" in the past and it did make the 92 run about 15 degrees cooler. That is an option. As is putting in a cooler thermostat. I have no idea what temp is in it now.
Thanks for the help
Old May 17, 2018 | 09:08 PM
C5 4me's Avatar
C5 4me
This could help you
https://www.corvetteforum.com/forums...peratures.html
Old May 17, 2018 | 09:44 PM
1analguy's Avatar
1analguy
Thanks for the help
Sounds like perfect operation to me. If you change the thermostat to a 160 and that's all you do, it won't run any cooler in hot weather...it'll just take longer to reach the same temperature.
Old May 17, 2018 | 10:06 PM
84Whitebird
ok, thats what I wanted to hear. Not used to what's NORMAL for these. It's a big help being here. Thanks
Old May 18, 2018 | 08:45 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Perfectly normal temps.
Old May 30, 2018 | 12:17 PM
1analguy's Avatar
1analguy
We've largely gotten used to the temperature gauges in our modern cars sitting steadily on 190F when they're warmed up. However, the 'temperature gauge' in a modern car is not a temperature gauge at all, its an 'idiot light' masquerading as a temperature gauge.
In modern cars, the engine temperature no longer directly controls what the gauge indicates. That's now the ECM's job. The ECM is programed with an acceptable 'window' of engine operating temperatures, and if the engine is operating within those norms, the ECM sends a 190F signal to the 'gauge' so the operator will know there's nothing amiss with the engine temperature. It will still display cold or out-of-acceptable-range hot temps...it has just taken some of the worry out of the equation.
Basically, they've 'dumbed it down' for us, though no one asked them to. Maybe they were tired of receiving complaints of engines running 'hot' when the engines were just fine...I don't know. What I do know is that personally, I prefer to know what the engine is actually doing at any given time.
To normal temp range?
