OBD 2 issues
Old May 28, 2018 | 07:13 PM
jesters94's Avatar
jesters94
2016 C4 of the Year Finalist
2015 C4 of the Year Finalist
Default OBD 2 issues
I have a 1994 I'm trying to get state inspected. The reader cannot communicate with the car to read the sensors. When I plug in my reader all I get is a link error. I know the reader works as I plugged it in to a different car and was able to pull information. I've checked fuses and they all seem okay.
Reader is plugged in, key in ignition, car on but not started. She has been sitting for a few months on a battery tender. Might I have shorted something?
Old May 28, 2018 | 07:35 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
'94and '95 were mongrel years for OBD. It's an OBD1 system with an OBD2 plug. Having the same issue with my '95, trying to find someone around here that can read it. Got a couple leads.
Old May 28, 2018 | 08:25 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
your going to have to find a older reader
Old May 28, 2018 | 11:13 PM
Kevova's Avatar
Kevova
You do have a problem. Car is OBD1. The ALDL connector indicates PCM is reflashed there is no prom to change. GM started reflashing ecms a year or so earlier on W cars in 93. The obd will still give flash and module codes as in earlier models.
Old May 29, 2018 | 01:35 AM
Paul Workman's Avatar
Paul Workman
94 & 95 were OBD-1 with an OBD-II ALDL connector. 96 C4s were the first OBD-II C4s, (accordimg to my scanner data sheet)
Switch the reader to OBD-I if the scanner supports it and try again
Old May 29, 2018 | 07:04 AM
jesters94's Avatar
jesters94
Thanks. I'll ask the mechanics if they have the capability to check the older system and see if it will pass.
Old May 29, 2018 | 07:26 AM
fake's Avatar
fake
Let the state inspection station bring up the codes. The Ob1 system is just a worth less code system . You can dump a ton of hours into finding codes that lead to dead ends, I know i have a 93 since new and spent many hours trying to bring codes up nothing ever came up correct. You can jump it out with a paper clip and get the same results as a $500.00 scan tool.
Old May 29, 2018 | 09:33 AM
jesters94's Avatar
jesters94
Thing is there are no codes....no check engine light....it just won't read the system to see all the sensors.....I keep getting a link error on my reader and the reader at the mechanics shop can't communicate with the car...
Old May 29, 2018 | 09:40 AM
JimLentz's Avatar
JimLentz
A GM Tech 2 should work for your scenario.
Old May 29, 2018 | 10:04 AM
WVZR-1's Avatar
WVZR-1
If the inspection station is having the issue - they 'don't get it' and if they're attempting 'EMISSIONS' they can't use OBD2 type connection. They should only require the 'KEY-ON/Bulb-Check' and do whatever is required for the jurisdiction to accomplish 'EMISSIONS' inspection. Varies 'jurisdiction to jurisdiction'.
There's nothing for you to do with a 'reader' that's related to EMISSIONS - You say you've 'NO CEL' - well if you have CEL/SES @ 'KEY-ON/Bulb Check > you're done.
Tell the inspector the car is OBD1 but only uses the OBD2 ALDL. They should be able to confirm that.
If NOT this then you're not explaining very well your real issue. Take another stab at the explanation. If you have a CEL/SES that stays on they're likely going to fail.
Old May 29, 2018 | 10:08 AM
jesters94's Avatar
jesters94
I'll talk to them and let you guys know how it went....thanks again!
Old May 29, 2018 | 10:26 AM
WVZR-1's Avatar
WVZR-1
There are very few Pxxxx codes that can be read using a correct 'scanner' for a '94 - I don't know of a 'reader' that can do any!!
Are you needing an 'EMISSION' or a safety inspection?
Old May 29, 2018 | 10:30 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
St. Jude Donor '16
OBD I should be a roller/sniffer test only, no need to even plug into the OBD I system.
Old May 29, 2018 | 12:31 PM
jesters94's Avatar
jesters94
Emissions. The car passed safety just fine.
Old May 29, 2018 | 01:06 PM
JBPC4's Avatar
JBPC4
As others have said. Obd1 emissions is a sniffer test, not a plug in test like obd2 cars. If they’re trying to scan it for emissions they’re doing it wrong. What state are you in and where are you getting it inspected? They should have software that tells them what protocol to perform on the vehicle based on the VIN. It shouldn’t be up to you to tell them the correct testing procedures.
Old May 29, 2018 | 01:23 PM
jesters94's Avatar
jesters94
Missouri. Inspection is at an Auto Tire.
Old May 29, 2018 | 01:28 PM
JBPC4's Avatar
JBPC4
I’d take it somewhere else if there’s another inspection shop around.
To OBD 2 issues
Old May 29, 2018 | 04:25 PM
MARKRUBYRED's Avatar
MARKRUBYRED
First, as stated before, your '94 is OBD 1 with OBD II plug. My '93 Ruby used to go thru emissions with sniffer and treadmill until it got historic plates from state of MD and now exempt. Check with your state MVA. As long as you are not using the 'Vette as a DD you could be saving yourself $$$ on emissions and safety inspection as well as registration, tags and insurance. Good luck
Old May 30, 2018 | 07:28 AM
jesters94's Avatar
jesters94
Went back to the mechanics and had a talk with the head mechanic. After a long talk it turns out I don't require a emissions test. This was confirmed when we called the Highway Patrol and talked to the Chief Inspector. Only vehicles 1996 and newer are now required to pass emissions.
Thanks all as I would not have even thought about that without your help!
Old May 30, 2018 | 11:38 PM
MatthewMiller's Avatar
MatthewMiller
I just saw this thread. I live by Cottleville, very close to you. I was all set to tell you this info, but I see you finally got the correct info from your mechanic. Yes, you are in good shape - no emissions required for any pre-OBD2 car (prior to 1996) in any county in MO. Only us 96 owners have to deal with it.
