Stuck in accessory mode
Old Jun 1, 2018 | 07:19 PM
riank's Avatar
riank
2nd Gear
Default Stuck in accessory mode
I have a 1991 Coupe. It was in storage all winter with a battery tender. I took it out this Spring and now the ignition is stuck in accessory mode draining the battery. Is there an easy fix or do I need a new ignition switch?
Old Jun 1, 2018 | 10:44 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
First, disconnect the battery for a minute or so then reconnect. See if the system reboots itself.
Old Jun 1, 2018 | 10:48 PM
riank's Avatar
riank
2nd Gear
Already tried that. Disconnected both pos and beg and put them together to drain system. Still happens.
Old Jun 2, 2018 | 09:07 AM
Kevova's Avatar
Kevova
If key won't rotate to lock. The problem is most likely the key cylinder.
If the key will come out. The most likely problem would be with the "rack kit" in the column.
Either way the top portion of the column would need to be disassembled.
To Stuck in accessory mode
