Dash Vents not working
Old Jun 11, 2018 | 06:42 PM
Kim Hil's Avatar
Kim Hil
Cruising
Default Dash Vents not working
I have a 95 LT1.
The air and heat both work great but nothing through the dash vents. Only out of the windshield defrost and floor.
I replaced the vacuum check valve under the fuel cover but it didn't help (it was cracked).
The vacuum works for the cruise so not sure if I have a vacuum leak or not.
Should I be looking at replacing the control module? (push button control module in the dash)
Any help would be greatly appreciated.
Old Jun 11, 2018 | 06:45 PM
Kevova's Avatar
Kevova
Still sounds like a vacuum problem. Digital or manual control.
Old Jun 12, 2018 | 09:23 AM
jts90vette's Avatar
jts90vette
2021 C4 of the Year - Unmodified Finalist
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
Do you have the manual or automatic climate control? It makes a difference as to what to trouble shoot.
Old Jun 12, 2018 | 09:54 AM
Kevova's Avatar
Kevova
Manual vacuum switching valve is attached to dash control.
digital or automatic climate control the control is electric only and uses programmer to switch vacuum and temperature doors.
To Dash Vents not working
