Steering wheel horn issues
Old Jun 15, 2018 | 10:59 PM
matthud's Avatar
matthud
Default Steering wheel horn issues
I went to replace my horn switches in my 95, when I went to connect the spring contact the plastic piece that is in the column broke. The small piece that holds the post on the spring contact was snapped off so it won't hold the horn spring piece in. Is this part available? How would I go and replace it? Is it part of the turn signal switch assembly?
Old Jun 16, 2018 | 08:39 AM
WVZR-1's Avatar
WVZR-1
Sounds as if you're describing the 'tower' on the directional cancelling cam.
Name:  GM 26047013.jpg
Old Jun 18, 2018 | 08:43 AM
matthud's Avatar
matthud
You are absolutely right, thanks. Replacement purchased.
To Steering wheel horn issues
By Michael S. Palmer | 2026-06-03 09:39:05
