tire replacements
Old Jun 18, 2018 | 12:06 AM
scottfranze's Avatar
scottfranze
1st Gear
Default tire replacements
have 1985 vette got rims from 2012 245/40/18 front 285/35/19 rear will these fit the 85 vette without spacer or is modification required
Old Jun 18, 2018 | 06:29 AM
hcbph's Avatar
hcbph
I think you're going to find your oem rims are either 32 or 38 backspacing on them while newer ones are 56 so there's a likelyhood you are going to have to use spacers to make them fit.
Check this website, I think it will help you decide: https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Old Jun 18, 2018 | 12:27 PM
1stVetteFinally's Avatar
1stVetteFinally
I had to use 1 inch spacers for the rear when I had a set of rims like that on my '92. Front fit fine.
Old Jun 18, 2018 | 02:09 PM
hcbph's Avatar
hcbph
Remember you have different offsets than the 85 so it affects the wheel fitment on the car.
To tire replacements
