"Hot" Corvette
Old Jun 19, 2018 | 08:58 AM
Larry Dudeck's Avatar
Larry Dudeck
Navigator
Default "Hot" Corvette
I have a 1985 C4 with the Targa top. I’m generally pleased with the car but there is one area that I’m not. That is just how hot the cabin can get on a hot, sunny day.
The glass top is a very dark gray, almost black in color. But still, on a bright, sunny day, the top transmits enough sun light to make the interior uncomfortably warm. This is especially noticeable when stopped a traffic light. And if parked, the cabin will feel like an oven if the car sits for any length of time.
I decided to do something about the problem. I thought if I attached to the inner surface of the top one those reflective shields, that we normally put against the windshield that would reflect the sun light, keeping the cabin much cooler. So I bought one of the folding windscreen sun shields and went to work.
I first removed the top and thoroughly cleaned the inner surface. I then cut the reflective shield to the shape of the inner top surface and held it in place with 12 pieces of 1” long Velcro hook and loop tape. Finally, I finished the cut edge with black electrical tape.
I put the top back on and tried it. I was amazed just how much cooler the cabin is. An extra benefit is a bit of noise reduction due to the foam backing of the reflective material. From the outside, the change is practically invisible; the reflective material isn’t seen unless you get very close.
The cost to do this was $3.50 for the shield, $1.50 for a piece of hook and loop Velcro and about one hour of time.
Old Jun 19, 2018 | 09:05 AM
JimLentz's Avatar
JimLentz
Nice!
Old Jun 19, 2018 | 12:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Good thinking.
When I received my '88 while on a summer job in Mesa, AZ, the top came off in the morning and stayed off till I returned to the hotel in evening. Even with white wheel & interior and light carpet dash pad it was very "warm" but nothing like being left closed up in the sun.
Since returning to SE NY, I sometimes use windshield screens but mostly stay out of the hot sun...
Old Jun 19, 2018 | 04:12 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
That's using your head.
Old Jun 22, 2018 | 09:42 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Where did you find the reflective shield material that would fit that size?
Old Jun 22, 2018 | 01:33 PM
TheBlaster9001's Avatar
TheBlaster9001
When I did a similar job, I ordered one of the big accordion style sun sheilds off of Amazon, then cut it to size with a box cutter, then sewed a new black seam on the outside. I works ok, although the car still gets crazy hot when in the sun.
To "Hot" Corvette
