No Start/Die
Old Jul 6, 2018 | 11:32 PM
Mishawaka's Avatar
Mishawaka
Default No Start/Die
Will a bad oil pressure sensor cause an engine to die like turning the ignition off, or not start? Working on multiple problems and trying to eliminate items.
Old Jul 7, 2018 | 08:22 PM
Kevova's Avatar
Kevova
It can effect fuel pump operation.
Old Jul 7, 2018 | 10:21 PM
playsdixie's Avatar
playsdixie
best place to start is to get a fuel pressure gauge going to see if it stays up......you get a 2 sec burst each time you key on, so starting shouldn't be a problem....
Old Jul 8, 2018 | 02:18 PM
Mishawaka's Avatar
Mishawaka
Its an intermittent start/die so its been difficult to see exactly whats going on. Ive heard a bad oil pressure sensor can cause a no start situation so Im just trying to eliminate possible problems.
Old Jul 8, 2018 | 05:35 PM
Kevova's Avatar
Kevova
You need to go through the basics Codes, spark, injector pulse, & fuel pressure.
To No Start/Die
