HELP- LT1 optispark problem!
Old Oct 21, 2002 | 05:51 PM
tgroghan's Avatar
tgroghan
Default HELP- LT1 optispark problem!
Okay I have an LT1 engine and it has the Optispark "distributor" type system on it. It's in an unconvential location, compared to the L98 motors distributor.
The problem that I'm having is that at high speeds the rotor is getting smashed into the cap, which totally demolishes the distributor and leaving me stranded on the side of the road. Why is the thing shifting around like this??? Is there a problem with the cam shaft on my motor?
The car ran 30 miles after the new Optispark was installed and boom it went dead along the highway. It's hooked to a manual transmission and has about 65k miles on the motor itself.
Please help,
Thad
tgroghan@juno.com
Old Oct 21, 2002 | 06:00 PM
rocketfinger's Avatar
rocketfinger
Default Re: HELP- LT1 optispark problem! (tgroghan)
Has your car been retro-fit with the LT1? If so, is it a 95-96 with the vented Opti-spark? What I'm wondering is if the fresh-air line is plugged and engine vacuum is collapsing the cap until it contacts the rotor. Kinda far fetched, but one possible explanation.
Old Oct 21, 2002 | 06:38 PM
tgroghan's Avatar
tgroghan
Default Re: HELP- LT1 optispark problem! (rocketfinger)
The LT1 motor is in a 1995 and the motor is a 1995 so it has the vented Optispark. That is definitely worth checking into.
Thanks,
Thad
Old Oct 22, 2002 | 11:49 AM
hotwilzz's Avatar
hotwilzz
the rotor actully has two screws that hold it in place, maybe someone forget to use them?
Old Oct 30, 2002 | 08:24 AM
tgroghan's Avatar
tgroghan
Okay we took the one apart, Optispark. The rotor was MELTED!!! When it melted it sent pieces of it touching the cap and it shattered.
My question, why is the rotor melting? Is the coil bad or the coil module? And how do I test these?
Thad
To HELP- LT1 optispark problem!
