Shifting
Old Jul 11, 2018 | 09:14 AM
mrk11462's Avatar
mrk11462
Cruising
Default Shifting
Good morning I have a 1995 vette it shifts good threw 1 and 2 hard into 3 no overdrive governor only has 35 psi can any one tell me how to or how to fix this with out putting a new trans in thanks mark
Old Jul 11, 2018 | 10:58 AM
TheBlaster9001's Avatar
TheBlaster9001
No overdrive? Why is that? When was fluid last changed? Where is the fluid level at?
And what is at 35psi?
Old Jul 11, 2018 | 11:32 AM
mrk11462's Avatar
mrk11462
Cruising
Fluid has been changed a last month ago I did that because it started acting up fluid level is right on the money the psi is at the governor. Thanks Mark
Old Jul 11, 2018 | 11:55 AM
TheBlaster9001
Did you delete overdrive? Or it won't engage 4th? 700r4, 4l60?
Old Jul 11, 2018 | 12:07 PM
mrk11462's Avatar
mrk11462
Cruising
No I did not it just stopped going into 4th from what I understand the pressure at governor should be 65 psi for it to shift into 4th gear but not sure of that I thought maybe something could be clogged up some where or the shift solenoid's are not working right
Old Jul 11, 2018 | 12:20 PM
TheBlaster9001
Was this issue present before fluid was changed? Was the pan dropped when you changed fluid, or was it just a system flush?
Old Jul 11, 2018 | 12:56 PM
mrk11462's Avatar
mrk11462
Cruising
I dropped the pan to do a fluid and filter change and some times it would shift and others it would not that why I changed the filter and fluid it only has 101k on the clock I just put my second set of tire on it two weeks ago so I don't beat on it.
Old Jul 11, 2018 | 12:57 PM
TheBlaster9001
Huh. How much clutch fluid was in the pan? Any shavings? What fluid did you use?
Old Jul 11, 2018 | 01:04 PM
Kevova's Avatar
Kevova
Codes? It's a 4l60e meaning electric shifting you need factory service manuals or a 4l60e service guide which can be found on some transmission supply sites. Good Luck..
Old Jul 11, 2018 | 01:05 PM
mrk11462's Avatar
mrk11462
Cruising
DEXRON III no shavings I'm am a mechanic myself and have done hundreds of filter and fluid changes just thought it would have fix this but it did not
To Shifting
