po153 code 1996 LT1
Old Jul 13, 2018 | 10:07 PM
Southern Boy's Avatar
Southern Boy
Cruising
Default po153 code 1996 LT1
I'm getting a po153 code for bank 2. It's about time to replace the O2 sensors. Where is the harness connector for the O2 sensor located? Thanks!
Old Jul 15, 2018 | 09:39 PM
ColaBear's Avatar
ColaBear
2018 C1 of Year Finalis4
There are 4 o2 sensors on the 96 LT1, 1 before the cat and 1 after the cat on both sides. A harness connects to each of the four o2 sensors.
Old Jul 15, 2018 | 09:48 PM
ColaBear's Avatar
ColaBear
The sensor has a pig tail harness with a connector. Separate the connectors and remove and replace the bad sensor. reconnect the harness.
File Type: pdf
To po153 code 1996 LT1
