1993 C4 electronic issues advice
Old Jul 17, 2018 | 03:31 PM
Haggisbash's Avatar
Haggisbash
Default 1993 C4 electronic issues advice
Hi, I usually hang out in the C3 section, I have a C3 (keeping it) but am hankering after a C4. Looking at a 1993 here with about 60k miles on it. My question is just how common are the Opti Spark, ECM failures and the like? reading a forum tends to give a view biased to the negative because obviously most people are here with a problem with the car not how well its going. Would I be better off saving and looking for a '95 - '96? Advice and owner experience appreciated!
Old Jul 17, 2018 | 03:42 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You will love the C4. It is a different car than the C3 and you will really (at least in my case) end up liking it better.
Opti problems are a bit overblown but they do fail. The best advice is buy a car that has already had the opti swapped and you will be good. 95/95 are better for the fact that they are the newest of the C4, but I would not hesitate to buy a clean 92-94. I have a 91 and I'd trust driving it anywhere.
Old Jul 17, 2018 | 03:53 PM
twichy2011's Avatar
twichy2011
I agree with bill, they aren't as bad as people make them out to be. I've been through my fair share of them (5 to be exact *All but 1 was a low res signal fault.... The other was a high res signal fault*). Turned out, I has an oil leak on the front of the intake which was causing the unit to fail. I haven't had an issue since I fixed that oil leak. 1992-1994 ECMs were more prone to failure, due to a heat issue, but aren't very common. The 95-96 ECM had a change made that allowed the ECM to cool better. That said I haven't had an issue with my ECM. I daily my 92
(162k miles), and it hasn't stranded me yet.
Old Jul 17, 2018 | 05:55 PM
RIC96's Avatar
RIC96
"I still have the original opti and ECM in my 96" he says as he cleans the coolant off the garage floor from the leaking throttle body hose.
To 1993 C4 electronic issues advice
