1990 FX3 suspension
Old Jul 26, 2018 | 08:43 PM
cash's90's Avatar
cash's90
Default 1990 FX3 suspension
I'm looking to buy a 1990 with the select ride FX3 suspension. How hard is it to replace the adjustable shocks with non-adjustable shocks?
Old Jul 26, 2018 | 08:55 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Just remove them and unplug and remove the actuators than the bulb from the DIC. You can also replace the switch assembly on the console with a non FX3 one.
Old Jul 27, 2018 | 11:24 AM
c4cruiser's Avatar
c4cruiser
Replacing the shocks is not terribly hard to do. The front shocks can be swapped even with the car on the ground!. The rear shocks are a little different. You have to remove the rear wheels and unbolt a small plate at the underside of the frame rail. Remove the nut at the bottom of the mounting stud, then pull the shock out. Remove the mounting plate and transfer it to the new shock and install the new shock.
The FX3 actuator is held in place on top of each shock by a circular spring clip. I would remove all of the actuators and keep them along with the clips. Disconnect the wiring at the connector and secure the harness so it won't get in the way. The rear wiring harness runs up inside the frame rail so secure them so that the don't fall down into the lower part of the frame. If you ever decide to return to the FX3 system, it will be a PITA to chase it.
The FX3 controller is located in the storage compartment behind the driver's seat. Remove the screw to raise the compartment lid. You should see the wiring harness that connects to the controller. Disconnect that harness from the controller. This should shut off the warning light (Service SRC).
Old Jul 27, 2018 | 12:12 PM
Cool Runnings's Avatar
Cool Runnings
Value of the car will be less, about $1,000 less.
Old Jul 27, 2018 | 01:39 PM
cash's90's Avatar
cash's90
Default Fx3
My non-FX3 1990, that I owned for 18 tears, suffered an electrical fire that damaged it beyond it beyond reasonable repair. I am looking to buy the 1990 with the FX3 suspension and replacing any questionable parts with the many newer parts that I can salvage from my car including the shocks. I have not yet looked at the candidate 1990 but am looking ahead to any potential problems. From my long experience with my damaged Corvette, any complex items, like the FX3, have either failed or have been disabled. If the FX3 works all is well.
Old Jul 27, 2018 | 04:02 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Good luck in your hunt. Lots of very nice C4s on the market right now.
Old Jul 29, 2018 | 06:30 PM
c4cruiser's Avatar
c4cruiser
Originally Posted by ihatebarkingdogs
IIRC, when the FX3 sets a code, (like removing the shocks) it limits the car's top speed to something like 85 MPH. Casper's has a kit that plugs into the harness and remedies this problem. I would think removing the connectors from the FX3 module would also disable the speed-limiter too. Does it?
Where did you see this?? I have read lots of posts here where owners have removed the FX3 shocks and actuators and never mentioned finding a speed limitation. My old '92 had FX3 and never had a speed limiting problem when I had to wait for a week to get a replacement actuator. A code was set because of that and I cleared it after installing the new part. I don't recall seeing anything in the Selective Ride Control section of the FSM that talks about limiting speed because the system is not working properly.
Old Jul 29, 2018 | 10:47 PM
aklim's Avatar
aklim
I would be more than that less. I would figure that for a restoration, assuming the harness is good, you have no actuators that are in working order and no shocks and module is suspect. Not that if I were to buy a C4 today I would make it work but that would be what I value it as.
To 1990 FX3 suspension
