Where does this go???
Old Aug 1, 2018 | 03:40 PM
bigc55's Avatar
bigc55
Default Where does this go???
Good afternoon.
Got done changing my plugs and have the ASR back in place but....
There is one connection that I have no idea here it goes. I can't see any plug it can connect to. I've attached a picture and would appreciate any guidance.
Thanks.
Old Aug 1, 2018 | 03:56 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Looks to me like the wire for the temperature sending unit. Look on the block, slightly below and between plugs 1 and 3 and see if there is a sending unit that is missing a wire.
Old Aug 1, 2018 | 04:10 PM
bigc55's Avatar
bigc55
Not seeing anything. The wire on the plug is very short too, like it should be going somewhere near the ASR. Could you possibly get a picture of what you're talking about?
Thanks.
Old Aug 1, 2018 | 04:41 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Originally Posted by ihatebarkingdogs
Brake master cyl switch. Look under the reservoir, between the metal line connections.
Should be a white sensor to plug it into.
From my 91 my 93 has a 2 wire plug.
Old Aug 1, 2018 | 06:17 PM
Roys92BlackRose's Avatar
Roys92BlackRose
I second the master cylinder connection. The plug looks identical o my 92, red and black wires.
Old Aug 1, 2018 | 10:39 PM
billschroeder5842
Yep, belay my last... that is the brake connection plug. I checked my 91 and it looks the same.
To Where does this go???
