Uncomfortable Seat Fix
Old Aug 3, 2018 | 12:13 AM
Silverfox1's Avatar
Silverfox1
Default Uncomfortable Seat Fix
My '96 has 19k mi on it, but just did 6 hr drive & thought I would die. Specific to left hip & sciatica. I know C4s are not known for their comfort. Anyone with thoughts on best cushions, etc? There are so many on Amazon. Not looking to replace seat. Despite low miles I know time can break down material, but not sure that a rebuild is answer. Car is fine for shorter drives.
Thx
Old Aug 3, 2018 | 03:37 AM
CVG323's Avatar
CVG323
sport or base seats?
I found base to be more comfy than sport.
my 94 had base seats and they werent bad at all.
my 92 has base seats as well and they are WAY more comfy than my 94.
Old Aug 3, 2018 | 04:55 AM
Paul Workman's Avatar
Paul Workman
And, as it happens, I have those same afflictions as the OP (arthritis in the hips AND sciatic issues). And, I found the base seats in my 95 LT1/M6 made that car the most comfy car I've ever driven! Either my tank would empty or my bladder fill way before the seats got uncomfortable. (In fact, I replaced the sport seats in my 90 Z with standard seats from a 95 and love 'em! Just returned from an eight day trip and romp in the Rocky Mt and NEVER had any comfort issues.)
If the OP has sport seats, I can relate: 90 sport seats were THE worst damn seats I ever had the displeasure to endure! But the 96 seats I've sat in are nothing like the ones from the 90 MY.
So, I guess my point is I would have to think maybe the comfort issues the OP complains about are more related to arthritis than the C4 seats themselves (which I think are the best, most comfy seats of any car I've ever driven cross country.) JMO.
Old Aug 3, 2018 | 07:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
Same issue..bursitis in hips. 90 Sport seats made them flare up bad...the 89s std could drive all day....Those bolsters will do that-
agree with the later C4 std seats being the best. These cars, even the C7 were made for little guys I guess.
Old Aug 3, 2018 | 01:41 PM
mickey5's Avatar
mickey5
My '90 with base leather seats had bottom cushion bolsters that pressed in against my thighs with resulting hip pain. I took out the cushion and tried to flatten the bolsters but found the wire support inside was made of tempered steel. Finally placed the cushion, bolster side down on the garage floor, and slowly rolled the car over it once. It flattened enough to make a difference but to force the cushion between the E brake cover and console makes adjustment impossible. Since I'm the only driver its a non issue.
Old Aug 3, 2018 | 01:44 PM
Silverfox1's Avatar
Silverfox1
Thank you all for input. The '96 has "Leather Adjustable Sport bucket Seats" (AQ9) . I guess the '96 would've been the best year of the Sport Seats. I think I'll try a gel pad on base as it seems pretty flat & unforgiving. It could also be this is my fate regardless of the seats. I'll try experimenting with the setting some more-maybe relaxing the side wings is the answer. I'll also research base seats. Can anyone tell me what structural difference there is between the two?
Old Aug 6, 2018 | 12:15 AM
joe wilson's Avatar
joe wilson
I tried out a 92 last week that had sport seats and that and a couple of other issues kept me from considering purchasing it. The seats were very narrow and the bolsters jabbed me in the side, very uncomfortable for even a short drive..My 85 on the other hand is very comfortable but it has regular seats.
Old Aug 6, 2018 | 12:52 AM
Silverfox1's Avatar
Silverfox1
It seems there are quite a lot of varying opinions on the various years & seat types. I think the '96 sports were as good as they get. I picked up a memory foam cushion at Walmart & immediately felt the difference. Whether that will translate to extended driving, don't know yet, but it's a start.
Old Aug 6, 2018 | 07:47 PM
SJW's Avatar
SJW
The base seats in my '96 were wonderful. The sport seats in my '94 are not. I'd gladly trade for a set of base seats in comparable condition.
Live well,
SJW
Old Aug 6, 2018 | 08:01 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I guess it all depends on the individual. I have had a bad back for almost 30 years (two lower spine surgeries) and I think that the sport seats in my 95 are the most comfortable seats in any corvette and I have sat in and driven C4s, C5s, C6s, and several C7s (though not for hours long rides in the C7 like in the other generations). I must admit though that due to other age related issues I have to make a pit stop about every hour anyway.
One thing to check in your 96 is the two straps under the seat cushion that support the seat cushion. It's a real long shot but ... if one of those straps is slightly torn it's possible that the seat bottom is not positioned correctly.
Old Aug 8, 2018 | 12:26 AM
Crossed Flags Fan's Avatar
Crossed Flags Fan
'95 has sport seats. I removed the bottom seat cushion and installed a 3/4 inch foam on top of the "straps" that are on the seat frame. Re-installed the bottom seat cushion and found my comfort level increased a lot.
Sitting on a memory foam cushion on the seat bottom may give the same relief, but it may get annoying keeping it in place as you get in and out of the car - which is a chore in itself..... .
Old Aug 8, 2018 | 12:46 AM
Silverfox1's Avatar
Silverfox1
Thx, I'll consider that for a longterm fix, but for the moment I'll stick with the cushion as a matter of convenience. Would be interested in the procedure to put the new foam in. Yes, they are a challenge to get in & out, but so fun to drive once you're in!
Old Aug 9, 2018 | 09:11 AM
-=Jeff=-'s Avatar
-=Jeff=-
I have found my custom 94-96 base/sport seats are the most comfortable for me..
Old Aug 9, 2018 | 12:43 PM
Silverfox1's Avatar
Silverfox1
Those are slick!
Old Aug 12, 2018 | 03:42 AM
gerardvg's Avatar
gerardvg
When i had my base seats re trimmed with new leather, they added more cushion / support in base and backrest.
Very comfortable for my butt and back, have been on a few over 1,100 mile 18 hour trips from Melbourne to Queensland here in OZ.
No sore back, comfortable and good support. Ready to go no need for spinal work afterwards.
Even with my stiff suspension...
To Uncomfortable Seat Fix
