Wheels
Old Aug 7, 2018 | 02:30 PM
Rlophat's Avatar
Rlophat
6th Gear
Default Wheels
Will wheels from a C5 Vette fit a C4 Vette?
Old Aug 7, 2018 | 02:41 PM
AgentEran's Avatar
AgentEran
Yes
Old Aug 7, 2018 | 02:43 PM
Roys92BlackRose's Avatar
Roys92BlackRose
Yes they will. I have the thinlines. They look good but are tucked in about an inch due to the higher offset, but they will bolt right on. Spacers can be used if needed but I don’t like them. Also, the fronts are 17” and the rears are 18” FYI.
Old Aug 7, 2018 | 02:45 PM
Rlophat's Avatar
Rlophat
6th Gear
Thanks.
Rlophat's Avatar
Rlophat
6th Gear
Originally Posted by AgentEran
Yes
Old Aug 7, 2018 | 02:48 PM
Rlophat's Avatar
Rlophat
6th Gear
Originally Posted by Rlophat
Thanks.
Yes, I know. I kind of thought bolt pattern would be the same but I questioned the offset and the 18s .
Old Aug 7, 2018 | 03:59 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Which year C4 matters. Early '84-'87 have lesser offsets than the rest. Typical 32mm-38mm versus 50+mm.
Old Aug 7, 2018 | 04:04 PM
hcbph's Avatar
hcbph
What he said. To use later ones on an early C4 may require spacers to make them fit, which personally I don't find desirable.
Old Aug 7, 2018 | 04:56 PM
kael's Avatar
kael
Keep in mind, there's spacers and SPACERS.
I bought some +40 offset wheels to put on my '87 expecting +38, there are 2mm spacers available. Only issue to keep an eye on, are the wheel studs long enough, Make sure lug nuts are getting at least 7-8 turns.
Old Aug 7, 2018 | 07:28 PM
joe wilson's Avatar
joe wilson
I have 2000 Corvette wheels on my 85 and used spacers to make it come out right. I didn't go with the 18" on the rear, just 17s all around. I haven't had a problem with the spacers.
Old Aug 8, 2018 | 07:24 AM
Rlophat's Avatar
Rlophat
6th Gear
1991 Coupe. Thanks.
Old Aug 8, 2018 | 07:26 AM
Rlophat's Avatar
Rlophat
6th Gear
1991 Coupe. Thanks.
Old Aug 8, 2018 | 11:33 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
They will fit you '91.
The base C5 rear wheels have a slightly different offset and will sit inboard a little without a spacer/adapter, but do not rub with stock size tires. An adapter can be used, but there are differing opinions on whether they are good or not. The fronts are fine.
I have listed the sizes and offsets for the late C4 wheels and the C5 wheels for your reference to see the differences.
88-96 base
16"x 8.5"- 50mm
17"x 8.5"- 56mm
17"x 9.5"- 56mm (also used for fronts on some models)
C5 base (wagon wheels/thinspokes/polished thinspokes/magnesium)
17"x 8.5"- 56mm
18"x 9.5"- 65mm
C5 Z06
17"x 9.5"- 54mm
18"x 10.5"- 58mm
I have had them on my cars without spacers as shown below. Like others said above, the rear C5 wheels are 18" and it will sit a little different higher in the rear which I did not like. Also if they still have the stock base C5 tires they are runflats and are very stiff. I did not like that either.
Good luck.
To Wheels
