Mildew after storage
Old Aug 10, 2018 | 10:56 PM
GammaMare's Avatar
GammaMare
7th Gear
C4 of Year Finalist (stock) 2019
Default Mildew after storage
My brand new, to me, 85 had been in storage with little ventilation over the past 10 years. What is the best way to remove mildew from interior items, such as the dash and leather steering wheel, and under the hood, hoses and other rubber. Remarkably the rubber is still pliable. Any help would be appreciated!
Old Aug 11, 2018 | 12:55 AM
Maldini's Avatar
Maldini
Had similar with mine. Grab yourself an all purpose cleaner (which generally comes in concentrate), and dilute it something like 10:1 - usually there are instructions/recommendations on the bottles. Wouldn't be a bad idea to do a test spot in an inconspicuous area just to ensure you won't do any harm. You should be fine though.
This is what I use, but by no means is it the only thing you can use. https://www.autogeek.net/pbapc32.html. You could do your entire interior with this. Mixed up a little stronger, and its a great engine, rim/tire cleaner as well.
Eric
Old Aug 11, 2018 | 10:40 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
As above.... get yourself some "Simple Green" dilute a bit and get after it. when you are done, som Armour All will help bring it bavck to life.
Congrats on the 85!
Old Aug 11, 2018 | 11:00 AM
RetroGuy's Avatar
RetroGuy
Default Prevent it first next time...
Use desiccant packs inside the car when storing for a long period. They make large packs for gun safes and storage chests. Also baking soda boxes with the tops opened can help too.
Old Aug 11, 2018 | 11:08 AM
Paul Workman's Avatar
Paul Workman
If the carpet becomes mildewed, that is a big problem. Depending on how bad, replacement might be the only way to "treat" mildew. (The biggie is the spores created that can get into your lungs or those of passengers and cause some serious issues. A good idea to wear a breathing mask for protection when dealing with moldy carpet!)
The dash and "hard" surfaces (leather/vinyl) I've used the interior protectant from Turtle Wax - seemed to work quite well. In really bad areas, 50/50 mix of Simple Green to get the heavy areas clean, followed by the protectant. (Turtle Wax leaves a high luster [shine], but Groits works well too, but leaves less of a shine - more natural look.)
To get rid of mold and cigarette smoke in the air ducting, I went on line to find a detailers aerosol 'bomb" that you activate while the AC/heater is running. You vacate the car and leave the vehicle closed up while the aerosol does its thing - takes about 20 minutes. And, don't forget to change the in-cabin filters (C4s don't have any, however)).
Good Luck!
Old Aug 11, 2018 | 11:51 AM
belairbrian's Avatar
belairbrian
I used Damprid Mold and Mildew Stain Remover until it was forced off the market for environmental concerns. That stuff was really good but apparently had some hazardous chemical.
Now I use Folex (Lowe's sells it) for cleaning interior cloth and carpet. For carpet I spray it on with a trigger sprayer then remove using a Bissell green machine with hot water.
For leather all I use is Griot's.
Old Aug 11, 2018 | 09:13 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
A product call Ozium will kill the smell in the car. Same thing happened to ours. It was in storage for most of the 10 yrs before we bought it. We had to have the seats redyed in order to get rid of the black mildew stains on the red leather. We scrubbed the carpet, cleaned the rest of the interior and I repetitively sprayed it for a few days with Ozium. You cannot tell it was ever mildewed.
Air the car out for a few minutes after using.
Old Aug 11, 2018 | 11:00 PM
belairbrian
For Odors I use Biocide. We bought our daughter a used Accord from a Honda dealer. Two days later it smelled like a combination of mold mildew and puke. No idea how they hid the smell. Cleaned the upholstery then set off the Biocide. It fills the car with a very nasty chlorine like gas for 24 hours, then you have to air it out for another day. But 3 years later and no smells.
Old Aug 12, 2018 | 08:56 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Remember to shampoo the rugs, great source for mildew.
Also door panels, and rear compartment with a good cleaner.
To Mildew after storage
