Quick body panel question.
Old Sep 2, 2018 | 10:43 AM
84 4+3's Avatar
84 4+3
Default Quick body panel question.
Hey guys. I have a rather stupid question. The front quarter (fender or whatever it is) next to the battery tray, the one you have to remove to replace the battery, was there a point in production where the lower bolt hole between the rocker and panel was notched to allow the panel to come completly off? I ask because I have heard that on the later cars you loosen that one and the panel pops off but on mine it is clearly a complete oval. I only ask because it scares me how much you have to bend the panel to get the battery out and that seemed like a good update. I'm just curious as I don't care all that much but wanted to know. These are things I think of when I'm bored.
Old Sep 2, 2018 | 11:20 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Yes, not sure what year it started.
Old Sep 2, 2018 | 01:00 PM
confab's Avatar
confab
I cut mine for that reason exactly.. It's an 85.
Old Sep 4, 2018 | 02:15 AM
topfuel67's Avatar
topfuel67
They are notched on my 89. Just had them off to paint.
Old Sep 4, 2018 | 05:52 PM
Kevova's Avatar
Kevova
You are actually supposed to take rear inner fender liner off. I found it's easier fender off.
Old Sep 4, 2018 | 10:30 PM
mfowler's Avatar
mfowler
My 1990 is notched.
Old Sep 4, 2018 | 11:57 PM
gpierce's Avatar
gpierce
88 is notched.
Old Sep 5, 2018 | 12:30 AM
84 4+3's Avatar
84 4+3
My liner seems like a pita to pull. I can do it in about 20 minutes now but it's still annoying replacing the battery on this thing.
I'm wondering if the switch was in 86...
Old Sep 5, 2018 | 08:26 AM
auto_cran's Avatar
auto_cran
My '84 was the same way (no notch - complete oval) - which I thought was odd. After owning an '89 and an '88 that both had the notch, I couldn't believe what a PIA the '84 was to remove the panel as I was expecting it to have the notch and simply slide out once the bolt is loosened (as described in the service manuals). Once I realized the panel wasn't coming off, like you, I didn't feel comfortable with how I had to bend the panel. I ended up loosening the rocker panel screws enough where I could properly remove the panel. Once off, I got my Dremel and made the notch, so I don't have to deal with it again...
auto_cran
To Quick body panel question.
