G-Tech Pro
Old Oct 26, 2002 | 02:03 AM
vette92_1's Avatar
vette92_1
Default G-Tech Pro
Is the G-tech pro really is good as they claim (they being the manufacture) or is it just another gimmick?
Old Oct 26, 2002 | 04:09 AM
ghall's Avatar
ghall
Default Re: G-Tech Pro (vette92_1)
If you don't have a grag strip around--it is an excellant tuning tool.The times will be very consistant(not 100% accurate)---.I think the mph is usually off around 2 mph and times usually .2 off for 1/4 mile runs.The 0-60 usually are very close.
Geoff Hall :seeya
Old Oct 26, 2002 | 09:07 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: G-Tech Pro (ghall)
Geoff Hall :seeya
I will agree with most of the above.
As long as you use it to compare yourself to yourself, it's a great tool. But using it against someone elses car with time slips and other data, I say it's not.
The G-Tech will calculate mph at the end of the 1/4 mile where the track measures a trap speed 66' before and at the finish line giving an average.
So the G-Tech will always read higher.
The ET's you have to be careful with also, if you let off to soon, it will give a false reading.
0-60, I went 5.7, but using a formula and my time slip it was really 4.12, but I don't believe either one.
Don't even try the HP calculator, it said my 6 banger pick up had 600 HP.
It's hard to dial in the weight for the HP calculator and you have to hit a certain"G" or 120 mph to get a #.
So bottom line, if you don't have access to a track, go ahead and buy one(look on ebay for a used one), if you can go to the track, put the money towards a set of drag radials. You'll be much better off.
Old Oct 26, 2002 | 04:52 PM
vette92_1's Avatar
vette92_1
Default Re: G-Tech Pro (Mr Mojo)
OK, thanks for the comments. The closest race track is a 2hr. drive, so basically what you guys said would work for me pretty well. I have already bid on one on ebay. Thanks again
To G-Tech Pro
