steering column fix
Old Oct 10, 2018 | 06:28 PM
doityourself's Avatar
doityourself
Default steering column fix
put upper and lower bearings in steering tilt housing put all back together all parts fit every thing works put column back in car ,wires back bolted back in place and there's not enough shaft to reach intermediate shaft coupling they touch but that's it I need 2" more shaft and its not there ? this is a 1996 there was not a problem at this coupling and now there is. there's about 3" of shaft showing past tail end bearing on column ? I looked at the shaft and those injected studs were ok ?
