Help ---- Help
Old Oct 10, 2018 | 11:21 PM
Majik1's Avatar
Majik1
Navigator
Default Help ---- Help
Hi Tadge, and all,
I have a problem with my 1988 Corvette, put in new fuel pump, new filter, new MAF sensor, starts right up, run great for 2 minutes, then I get a "roar" from the intake and it will not run, shut it off and it starts, but only the "roar" when stepping down on the accelerator, no codes and nothing from the code connector, (an y readings, blank)
Old Oct 11, 2018 | 01:29 PM
ls777z's Avatar
ls777z
a HUGE vacumn leak ???
Old Oct 11, 2018 | 01:56 PM
Majik1's Avatar
Majik1
Navigator
Thank you Is777z,
I will check it out, I did put in new vacuum lines, couldn't remember al the connections. Maybe something connected wrong ???
Majik1
Old Oct 11, 2018 | 03:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A manifold vac. gauge is often very helpful along with a variety of vac. lines and connectors.
Old Oct 11, 2018 | 05:50 PM
playsdixie's Avatar
playsdixie
Originally Posted by Majik1
Thank you Is777z,
Majik1
Maybe??????.....
by the way, welcome to the forum.....
Old Oct 11, 2018 | 08:03 PM
JBPC4's Avatar
JBPC4
You mentioned replacing the maf, check the intake connections around that and the throttle body, especially on the underside where it’s hard to see. It’s easy for the rubber hose to get caught up on the bottom of the throttle body and not seal properly, which would cause a huge vacuum leak of unmetered air coming in after the maf. That would also explain why it runs fine for the first few minutes while it’s still in open loop mode, then when it switches to closed loop it runs like poop.
Old Oct 11, 2018 | 10:29 PM
Majik1's Avatar
Majik1
Navigator
Hi 65Z01,
Thank you, I will see what I can do, never had this problem with ANY car over the years. That is why I am so stumped !!!
Old Oct 11, 2018 | 10:32 PM
Majik1's Avatar
Majik1
Navigator
Hi JBPC4,
This is the second MAF I have put on, the "air pump" by the A/C does click a lot. Don't know any thing about that, Once again thank you for your help, it is well appreciated !!!
Majik1
Old Oct 12, 2018 | 08:00 AM
playsdixie's Avatar
playsdixie
If you can't find on the basis of the sound you described, try spraying some throttle body cleaner around the lines....the rpm's will pick up when your spray finds the leak.....it takes more that a couple minutes to go into closed loop ..good luck..no smoking during this test...
Old Oct 12, 2018 | 01:29 PM
Majik1's Avatar
Majik1
Navigator
Hi playsdixie,
Thank you for the info, tried that, also disconnected all lines, (blocked them) and put them back on one at a time, same problem.
Majik1
Old Oct 12, 2018 | 07:10 PM
ghoastrider1's Avatar
ghoastrider1
ihis may sound dumb, but dod u put the fuel filter arrows going in the correct direction?
Old Oct 12, 2018 | 08:37 PM
Majik1's Avatar
Majik1
Navigator
Hi ghoastrider1,
Thank you, that is not dumb, I really need to check that, but, it runs great for 2 minutes, then I step on the gas and all it does is roar, (all air, no gas).
Majik1
Old Oct 13, 2018 | 11:27 AM
playsdixie's Avatar
playsdixie
when it dies, does the fuel pressure stay up?
Old Oct 13, 2018 | 01:49 PM
Majik1's Avatar
Majik1
Navigator
Yes it does, checked fuel pressure with Gguage, 40lbs
To Help ---- Help
