Digital Dash Problem
Old Nov 1, 2018 | 05:18 AM
Domobomb's Avatar
Domobomb
Default Digital Dash Problem
Hey guys,
Just have a problem with my 1985 dash. The central cluster showing the voltage, oil pressure, fuel consumption etc. does not work - it goes blank when the car is running.
When the key is in ign on the voltage will show constantly no problem. The oil pressure and voltage will show for a split second when starting the car, then it goes completely blank. The range and mpg are blank and stay blank. Not 0, just blank completely.
Speedo, Tach, Fuel Level all work properly.
When initially power is on to the cluster, everything appears like this as it should: Then goes blank instead of showing numbers.
Old Nov 1, 2018 | 09:01 AM
Randy M's Avatar
Randy M
We all recommend this place to solve your problems.
http://batee.com/
