Humidity vs Storage??
Where can I find something that will absorb any more moisture that gets trapped in there? Don't they make large desiccant containers or something like that?
So where is the issue with the concrete being damp? What does that do to the car?
By parking on a carpet barrier, the amount of condensation is cut way down (go figure?) - this phenomenon observed after decades of living in 'the flat lands'.
Never parked 'em on carpets, tarps or anything else. These cars are still with us....they've survived the ordeal, unscathed.
In your case, you mentioned the "engine and even the body panels". Where is the water coming from? Is it leeching up through the concrete? Doubtful. It's condensing on colder surfaces as the air temp warms and the surface (engine, for example) lags in warming, water condenses on the cool surfaces. The solution is to dry that air, insulate the facility (to prevent rapid temp changes) or heat it. If you put a tarp behind your bathroom mirror, water is still going to condense on the mirror when you take a shower. Water isn't coming through the wall....but it is condensing out of the warm, humid air that you've made by taking a shower.
IDK what a carpet does other than absorb water, get moldy and nasty and add a step to your winterizing process. Maybe it does something....but I'm going to go ahead and keep not-worrying about it.
My storage is a typical, an un-insulated garage - un-heated with a vented roof. After a sub-zero spell, the cars and the concrete slab cold-soak. in the middle of the day, even in sub-zero weather, the sun beating down on the roof brings the ambient air temps above freezing and water vapor condenses on the much colder surfaces of the cars - any exposed surface, including the concrete slab. NO the carpet does NOT get wet, and if I lift a corner to inspect the floor, there is a sharp line between the DRY AREA under the carpet and the bare concrete exposed to the air. (In fact, I've entered the garage after a cold snap when the temps outside were above freezing, and everything was dry. But, as soon as I opened the garage door and the "warm" wet air hits the cold cars/floor, in a matter of seconds the cars and the exposed areas of the concrete become wet!!
And, for the record, it was someone's recommendation on THIS FORUM suggesting the carpet idea. Works 4 me!! The FACTS are...it works (in my situation).
My hypothesis is: the surfaces of body panels quickly warm up to ambient temp and water stops condensing. the engine takes longer, but with the hood sealed, the moist air doesn't get to circulate as freely around the engine, UNTIL the hood is opened. When I do that, the motor surfaces become wet in seconds - like breathing on a mirror. , but the concrete acts (I suppose) like a heat sink which keeps the car cold unless the insulating affect of the carpet prevents the concrete from keeping the car from warming to ambient.
Does (carpet) apply in every situation? IDK either, but IT DOES WORK in my circumstances too; just like whomever first suggested using carpet said it would.
As always...YOUR MILEAGE MAY VARY!
...or carpet squares! or...or...something!
