Double din in an 85
Old 06-14-2019, 12:53 PM
Raidmagic
Raidmagic's Avatar
Originally Posted by RockyL32
I have been looking at Your comvette project with a lot of interest. I don’t think I have the programming or coding know how to do it .
Raidmagic did you put your heater and AC controls somewhere else or just not running any.
I did an LS swap too and it doesn't have any. Every time I am going to put AC in it I spend the money on some thing else for another car. Bad discipline but I've planned for it to go below the radio in that open space when/if I ever get around to it.
Old 06-23-2019, 06:28 AM
Apache 84
Apache 84's Avatar
What system did you use,it looks great and without dash mods.
Old 06-23-2019, 07:18 PM
LWesthaver
LWesthaver's Avatar
Who was this question directed to?
If it was me, I built my own head unit. You can see more here: The Comvette Project
-Wes
Old 01-01-2021, 10:14 PM
Robs1988
Robs1988's Avatar
Originally Posted by Dt86
You will have to trim the plastic bracket behind the dash so that the double din headunit fits inside. It is a tight space with all of the wiring harnesses that run behind it. As I recall I also made up metal brackets for each side to secure it in place.
As for the bezel, You have two options. You can buy a double din bezel or trim and fill yours. You trim a little from the top and bottom and then you have to fill in the sides.
this looks amazing! can you reply with part numbers or info on all components you used?
Old 04-27-2021, 06:18 PM
Los211
3rd Gear
Los211's Avatar
Default I need help with bypassing the Bose system
How to bypass do I have to re wire the whole car or I can use the same wires to by pass
Originally Posted by gerardvg
Hi
I have a pioneer double din with gps in my 85,note the fascia needs to be modified.
That is the hardest part, need to cut sections and fit the double din surround and use filler to make it fit and look good.
Of course going from bose to aftermarket, needs the bose amps in doors and rear to be bypassed.
I had a kenwood stereo in there before so that was done already.
It looks great well worth the effort, cant supply pictures due to photo bucket issues.
Old 04-27-2021, 06:31 PM
PacerX
PacerX's Avatar
I just ran wires. 18 GA.
I did that for a few reasons...
1. 4.5" Bose speakers are kinda tiny. I wanted 6". Good quality speakers are dirt cheap.
2. Why have the weight of the amps if you aren't going to use them?
3. There are blank off plates made to fill in the holes. Work great.
4. It's dead simple to run the wires. You can fish right thru the door grommets for the fronts and the rears just run under the carpet.
5. It was a fun project.
Old 04-27-2021, 07:44 PM
Los211
3rd Gear
Los211's Avatar
Is hard to remove the old factory amp ?
Old 04-27-2021, 08:39 PM
Bckmstr
Bckmstr's Avatar
Here’s what i did to mine
Before....
After
Removed cigarette lighter and installed usb for apple car play
Added infrared back up camera
Quick Reply: Double din in an 85
