Atari speedo question.
Old Nov 25, 2018 | 02:52 PM
Rohn's Avatar
Rohn
Default Atari speedo question.
1984 C4.
Replaced the 4+3 with a Tremec TKO 600 that I need to calibrate speedo with a Dakota Digital signal interface unit.
My options are to recalibrate a signal of 32,000-250,000 ppm(high speed) for an OEM speedometer
Or recalibrate a signal(low speed) of 32,000-4,000 ppm(not a typo) for a OEM speedometer
Or to convert a high speed signal to low speed signal from a newer GM tranny
Which do you feel is correct?
Other options exist to convert signal for a newer EFI computer. I am using a Dynamic EFI computer which is a converted GM TPI computer(92 Vette).
Old Nov 25, 2018 | 03:17 PM
tequilaboy's Avatar
tequilaboy
Its a 2k ppm signal, so hopefully your interface can deal with it. My old Dakota Digital SGI-5 with dip-switches works fine.
