A4 Neutral Safety Switch
Old Dec 8, 2018 | 06:45 PM
Bill Gonzalez's Avatar
Bill Gonzalez
2nd Gear
Default A4 Neutral Safety Switch
Ive got a 93 Typhoon which has the C4 Corvette shifter in it from the factory, and my neutral safety switch crapped out. I’ve determined it’s part number as 1994242. But I see it’s a discontinued part and Gm had no updated part number. I’ve chased down every aftermarket cross referenced part number I can find. But there seems to be nothing new available. And I’d rather not go the used route. This discontinued part surprises me given the size of the Corvette community. I was wondering if you guys have figured it a solution? For the time being, I’ve done the bypass.
thanks
Old Dec 8, 2018 | 08:13 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
https://www.corvettecentral.com/87-9...-switch-702937
Old Dec 8, 2018 | 09:41 PM
WVZR-1's Avatar
WVZR-1
That's a 'clutch safety' and the OP is looking for an A4 - 4L60! The OP I'm sure has the correct information and part #. He's done his research quite well!!!
To A4 Neutral Safety Switch
