front tag plate
Old Jan 3, 2019 | 10:20 AM
marines's Avatar
marines
Default front tag plate
Just a short question, what is the best way to remove the front tag plate on a 1996 Corvette? From the outside or from the hood area. Thank you so very much I really appreciate the help I get from the forum. God Bless. Good Morning
Old Jan 3, 2019 | 10:52 AM
WVZR-1's Avatar
WVZR-1
If this is the 'body color' insert then there should be 2 fasteners accessible in the 'seam' @ the top or bottom edge of the body color insert. I'd maybe expect Torx but if it's been done a time or two expect anything. Check the 'seams' it should become obvious.
Old Jan 3, 2019 | 04:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Can't recall where they were on my '88 but a strong flashlight beam into the upper & lower "seams" will reveal where the screws are located.
To front tag plate
