Extended battery terminals
Old Jan 11, 2019 | 04:52 PM
MRPVette's Avatar
MRPVette
Default Extended battery terminals
Has anybody added any type of extended battery terminal or longer bolts etc to help with jump starts or charging.?
Old Jan 11, 2019 | 06:25 PM
mlm0's Avatar
mlm0
If you are talking about the screw in type, I bought some at Walmart in the auto battery department. They gave me about another 3/4 inche of protruding bolt
Old Jan 11, 2019 | 07:15 PM
Izzy Dizzy's Avatar
Izzy Dizzy
I bought a pair from Amazon a couple of years ago. Removed the factory studs from the cables and replaced them with a longer version. I did this so I could wire in a battery minder as I didn't want to use the alligator clips.
Old Jan 12, 2019 | 12:02 PM
playsdixie's Avatar
playsdixie
I put quick disconnects on both terminals to get them above the battery and make for easier contacts for charging or testing.....
Old Jan 12, 2019 | 12:48 PM
NavAir's Avatar
NavAir
I also use them for the Battery Minder harness. They have worked very well. The harness quick-disconnect comes out below the front bumper for connection to my battery Minder harness.
Old Jan 14, 2019 | 11:26 AM
MRPVette's Avatar
MRPVette
I just added some today WOW I should of done this 6 years ago
To Extended battery terminals
