wheels
Old Jan 13, 2019 | 06:02 PM
redonec4's Avatar
redonec4
Cruising
Default wheels
what has to be done to fit a 1986 corvette with a decent wheel thanks for any help
Old Jan 14, 2019 | 04:35 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
First step, pick out a style. I assume you plan to stay with either 9.5" or 8.5" wide.
Key then is what the offset measurement is for that wheel. Refer to:
http://www.mirrockcorvette.com/corve...de-wheels.html
For specifics on stock wheels. Note for an '86, 8.5" needs to be +32mm, 9.5" +38mm.
If the offset of the new wheels is significantly different, may consider putting wheel adapters in place. Start with this thread:
Old Jan 16, 2019 | 12:31 AM
MatthewMiller's Avatar
MatthewMiller
Originally Posted by kael
If the offset of the new wheels is significantly greater, may consider putting wheel adapters in place.
Just tweaking your post to add clarity. This is correct, and it's good because most later cars (including 88-96 C4s) have more offset. You can use those wheels with spacers.
Old Jan 16, 2019 | 03:21 PM
hcbph's Avatar
hcbph
9.5"x18" 40 backspace rims with 255x40zr18 tires. Fit just like the original tires and rims, handles well and rides very good. Get the right backspace and they fit just fine. This is a 86 convertible that had 9.5"x16" 38 backspace rims with 245x50zr16 tires on it when I purchased it. Has the same diameter as the oem tires so even the speedometer is unaffected.
To wheels
