93 convert hardtop
I waithed 3 years to get the right one, and saw prices ranging from $800 to $1800.
You will find the best prices in the for sale section here on the forum...if you can find a top. Post that you are looking.
Next would be EBAY..
Also, use your search engine and type in Corvette salvage yards, or Corvette used parts. The prices, if you can find one will be the highest here. A salvage yard wnted $1800 for one last year.
Make sure the top includes ALL mounting hardware AND the rear shelf.
These Items are virtually impossoble to find as seperate items
good luck :yesnod:
All hardtops have a defogger grid and the power lead is in a harness by the passenger-side shoulder belt attaching tower but the ground lead on the driver's side only came on cars with the factory hardtop option. That lead is no longer available so you will have to make one.
Make sure the weatherstripping is in good shape. A full replacement set of weatherstrip for the hardtop is close to $700!!
I paid $800 for my top and $400 for painting to match.
you may want to follow up on some of these to see if they might still be avaulable.
if this link doent work.... go to "search" at the top of the page. Type in "hartop" , search in C-4 parts for sale, and search in "archive"
http://forums.corvetteforum.com/zerosearch
Also, could this be used to make my car legal past the 14 sec mark for NHRA? I won't get a rollbar but if this can get me past it for another 1 or 2 sec, then it would probably be worth it.
It latches in the same 2 positions the convertable top does in the rear deck.
There are also 2 bolts in the rear corner that locks it down in those latches.
Then there are 2 bollts in the top of the winshield frame. These are the same connections that the coupe guys use to attach their targa top.
Then, on each side, behind the seats, are connection points for the mounting brackets that have 5 bollts each. (10 bolts total for both sides)
YES, it DOES make the car legal for dragracing down to 11.99.
(thats why I have mine.
With practice, the top can be installed in about 10 minutes, using a garage hoist, or a second person.
The top wieghs 63lbs, ans is too cumbersome to be handled by a single person.
http://www.contemporarycorvette.com/specials.htm
