1996 fuel injector replacement
Hey everyone, first time posting...
I have a 1996 LT4 with 24# fuel injectors that need replacement. What are your suggestions for best fuel injectors that are both efficent and cost effective. Not looking to get the cheapest but also hoping to not take out a second mortgage. Any and all suggestions will be appreciated. Thanks in advance.
Here are some rebuilts
https://fuelinjectorconnection.com/c...l-injector-set
Your factory ECM is set for 27lb per hr injectors. I just looked at a sample table that I have that a fellow board member gave me for his car. If you don't stay stock you will have to reprogram, so the 26lb'ers above will go right in.
Here are the new ones. A big jump in price. Fellow board members use rebuilts.
https://fuelinjectorconnection.com/c...high-impedance
Thanks for the clarification on the correct size injector for the LT4. Current injectors have no ID number to verify size. Heard the Bosch III injectors are more reliable with today's fuels then OEM injectors. Diffidently wanted correct sized injectors for the factory ECM. Thanks again for all the responses on this issue I feel confident now that I will be ordering the correct injectors.
I bought a set of rebuilt injectors from fuelinjectorconnection for my 89 (L98) a few years back. They came with all the gaskets I needed. I called and spoke to them about what I was looking for and I got prices and I had them in a few days after I ordered them. I was told if I had any questions about installation to call and they would help. Can't beat the prices for the quality and support.
